Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-28-2005, 05:13 PM
carlhnt carlhnt is offline
getting 94 crown vic out of park
i have a 94 crown vic and can not get it out of park. it is a police edition. any suggestions
Old 09-28-2005, 05:47 PM
Xtra_X's Avatar
Xtra_X Xtra_X is offline
Send a message via Yahoo to Xtra_X
When you start the car can you turn the steering wheel or is it locked?
when you press on the brake to do hear a click? I can't remember what it is called but there is a safety feature on these cars that won't allow you to change out of park without depressing the brake. It may be damaged.
Can you move the gear selector? Is it jammed or is the selector moving but the transmission not changeing gears.
MORE INFO REQUIRED TO HELP YOU!!!
'94 Crown Victoria PI
'98 ZX2, 15" Motegi MR7, Keman Intake.
My Car Domain
A Canuck, not a Shatner stealing Mexico toucher
Old 09-28-2005, 06:17 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: getting 94 crown vic out of park
Check to see if you have brake lights. If no brake lights, look at the connector on brake switch or the switch itself. Ford had a problem with the connector breaking apart. You can get it out of park by turning the key one notch past lock, place shifter in neutral, start car and put it in gear.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-29-2005, 06:34 AM
Turbo_Cobra Turbo_Cobra is offline
Send a message via Yahoo to Turbo_Cobra
My 94 Crown Vic would not go into park...a bolt had come loose under the dash that holds a bracket for the shift cable. Also had to readjust linkage at transmission.
1979 Mustang Cobra Turbo
1974 Chevrolet K5 Blazer 4X4 Hardtop Convertible
1994 Ford Crown Victoria
1978 Ford F150 4X4
1978 Ford Mustang II T-Top
