Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 09-28-2005, 05:52 PM
Eltronic Eltronic is offline
Angry passener side window stuck open need to remove panel
passenger side window stuck open. I can hear motor attempting to raise the window. I have removed several door panel screws but I am afraid to use pry force to loosen door panel. What damage will I do if I go ahead and pop it loose. Will I be able to snap it back in place easily?
I need to remove the panel to find out why the raise/lower mechanism quit working.
Eltronic
Old 09-28-2005, 09:24 PM
Towncar's Avatar
Towncar Towncar is offline
Try this Conti thread....
http://www.automotiveforums.com/vbul...ght=Door+Panel
-Steven
1996 Town Car, Cartier
Old 10-17-2005, 05:45 PM
edflores edflores is offline
Re: passener side window stuck open need to remove panel
Eltronic
hey, man mine window did the same thing , you take the screw on the front side of the panel and the two on the handle. Than you snap it off, it doesn't take much pressure . and you wont brake nothing . but your problem is that inside of your motor is out . i know you can hear it but you need a new motor with the regulator , try a wreck yard its a lot cheaper. but if you never change a power motor i recommend that you take it to some one .
