Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 09-28-2005, 04:21 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
Car doesnt idle too well...
My car doesnt idle too well...here we go.
When im idling the car will dip like 50 or so RPMs and sometimes that drop will feel kinda like a miss. The car sometimes on start-up...starts really rough and you have to give it some gas to get it above 1000 RPM and then it goes to the previous mentioned symptom.
Im thinking it is the Catalytic converter and that its clogged and with too much back pressure its pushing Exhaust into the cylinder as it opens on cranking. No missing or bogging after 1000 RPM.... Also if NissanFanatic could PM me how he went about using his seafoam. I was thinking of injecting it through IACV and soem into Crankcase and then some into the Fuel.
EDIT: I also plan on changing the Fuel Filter as well. Anyone know anyways of getting the Fuel Line off without having to replace the lines?
Thanks
Old 09-29-2005, 02:50 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Car doesnt idle too well...
I do not think its the cat, if that was the case you have a lot more pressure in the exhaust system when the car was revving higher.
Idle can be effected by a of things. I have had my MAF screw up that effected the idle, also a coil pack, and a spark plug wire.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 09-29-2005, 05:11 PM
monooxide's Avatar
Banned
What?
What should a Spark plug wire run in resistance? well if theyre all the same that will be fine to me....If it was a wire wouldnt it be topend problem as well. Also...Can i run the Z32 MAF while im N/A?
Old 10-11-2005, 04:16 AM
slideways...'s Avatar
slideways... slideways... is offline
if your basic tune up parts are ok, id say check for vacuum leaks. other than that, check timing, 02 sensor.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 10-12-2005, 01:19 PM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
fuel lines should come off if you slowly twist them off. don't try and use a vice grip or anything similar because that'll just rip it right off. be sure to remove the pressure before u replace b/c u'll end up shooting fuel everywhere.
if it's a s13 (relatively old, like mine) grounding issues could be it as well. Make sure the battery negative terminal is grounded well... could be lots of excess currents running everywhere.
1993 RMS13 5MT KA
