| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
My 1988 s10 4.3 T.B.I. blazer is very hard to cold start. Dies for 10 minutes at least. When warmed up runs fine and restarts fine. Any suggestion to a possible solution would be appreciated. My son replaced the electronic pick up unit in the distributer because of hard starting hot and shortly after this new problem appeared. I suspect it could be throttle position sensor or ecu but really don't have a clue. My son uses this vehicle to commute to welding school so I really need it right.
Thanks Jack |
#2 | |
Re: 88 s10blazer very hard cold start
Have you checked/changed out the coolant temp sensor? It's right there smack dab of the middle front intake manifold. If your computer isn't getting the correct reading from it it may think the motor is 200* when it's really outside temp. That's the first thing I'd look at.
Second thing would be the fuel pump prime relay but I'd go with the temp sensor first. I apologize that I do not have the resistance specs on me. An auto parts store might have them. A dealership will have them but around here at least, getting a dealership to give up specs is like pullin' teeth. Josh <><
1989 Chevy/GMC "Blimmy," 4.3 motor, the only motor I've ever had that I've left stock ![]() 1993 Olds Bravada with the works. My firearms board, in association with Hipowers and Handguns.com:Click Here |
#3 | ||
Re: Re: 88 s10blazer very hard cold start
Thanks Jack |
