Old 09-28-2005, 01:24 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
Oil light flashing at idle??
Hey everyone! I noticed my RS oil light keeps flickering on and off when im at a dead stop. I changed my oil today and it still does the same thing so does anyone know what is causing my car to do that? When then car is moving the oil light shuts off but when i come back to a dead stop thats when it wants to come on. So anyone knows?
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 09-28-2005, 01:39 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Oil light flashing at idle??
My Oldsmobile does the same. Bad sensor. Get it replaced. It only flickered when stopped. Replaced and worked fine
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-28-2005, 01:41 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Replace you oil pressure sending unit (one for the idiot light).
Mine started doing this about 2 weeks ago....oil level is fine and my stock gauge reads exactly the same as it did 4 years ago when I got the car. The senders are know to go bad.
I don't know about the RS, but mine was $21 from Satan.
If you don't have a gauge on the dash, you might want to be careful seeing as how you can't verify if your oil pump is dying.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-28-2005, 01:43 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
I had the same problem on my RS and it just fixed itself. I never touched the car and the oil light would turn on when I have stopped or when making a sharp turn. I know its a sensor that has gone bad but there were so many so i never fixed it and it went away by itself. however I was thinking that if its a sensor wouldnt the check engine light turn on ? Hey hella fresh are you getting a GSX or decided to keep your RS ?
1997 Eclipse GSX
Old 09-28-2005, 02:00 PM
Re: Re: Oil light flashing at idle??
No, not with the idiot lights on the dash. Now if your MAS died or an O2 died, then you would get a CEL.
1997 Spyder GS-T
5-Speed
Old 09-28-2005, 05:05 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Mine did the same thing and then once it just died and i smelled a little plastic burning,so i pop the hood and notice that stupid me did not pull my intake pipe up high enough off all the wires that run under it,and some were melted and it shorted them out.So i got them fixed and the dude said he move it for me,then yesterday at least a week after he fixed it it started doing it again so i poped the hood again and it was still close and those wires were hot again so i lifted the intake up a little higher and puff no more light flickerin,so maybe it something easy like that so take a look it cant kill ya hope it helps
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 09-28-2005, 08:04 PM
Black97GST Black97GST is offline
a car can't fix its self, it doesn't have a brain to tell what to fix when something goes wrong. Maybe the light burnt out eventually??? just my 2 cents
Old 10-03-2005, 12:49 AM
eclipse912006 eclipse912006 is offline
Talking Idle Problem
I had that prolem on my 91 eclipse a couple of months ago. Find the oil pressure sending unit and check if the cable are not touching. That was my problem bacuse it was creating a short. If not get yourself a manual like at auto zone for your car it explains it more there.
