Old 09-28-2005, 12:41 PM
LyndsiK LyndsiK is offline
O2 sensor
i have a 97 gase, and i took it to auto zone for diagnostics and was told that there was a heater circuit malfunction and the guy said that was the oxygen sensor....does that sound right? anybody?!
Old 09-28-2005, 01:12 PM
maxwedge maxwedge is offline
A990 racer
Re: O2 sensor
The code was??
Old 09-28-2005, 01:16 PM
Re: O2 sensor
P0141
Old 09-28-2005, 01:39 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: O2 sensor
That is correct. That's what is specified for that code.
Old 09-28-2005, 03:07 PM
A990 racer
Re: O2 sensor
Check the o2 fuses first, check for 12v at the harness connector at the sensor, also check the ground for that heated circuit at the sensor, if both good the o2 is bad, you should try and get a wiring diagram for those circuits.
Old 12-16-2005, 10:14 PM
Nocturnall Nocturnall is offline
Send a message via AIM to Nocturnall
Re: Re: O2 sensor
Would it be the same for a 99 GT with a po135 code? Same definition but it's sensor 1 instead of sensor 2. Where is the O2 sensor locted in the exhaust? Drive side by the front tire?
