Old 09-28-2005, 11:51 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
I think i messed up my motor!!!!! HELP!!!
Well went to the track last night, did not go well. After about an hour i decided to run my car, the line was so long when the line would move i would start my car move 10 feet then shut off, then 5 minutes go by and do the same thing. On the 3rd time starting my car it did not start, it just turned over and back firing, smelled like alot of raw fuel comming out the exhaust. It would spit and sputter a little for like 3 seconds then stop. Crank over again and just pop and go at it. So guess WHAT!!!!
My brother and I where stranded in canada for the night!!!!! Could not get anyone to flatbed it back across the boarded. So we slept in my car!!! cold as hell, i was not leaving it in canada,NO WAY!!. Anyways the motor did not sound like anything broke or bound up, it just pops like hell and not run. No valve banging off pistons, it sounds normal turning over. I checked the timing belt out at 5am in canada because we could not sleep, and the belt looks fine, would the belt jump a tooth and look fine? Can the timing jump 1 tooth and not bend valves? I changed the plugs that morning up there and still did the same thing. Just by shutting my car off and on did this shit what happen? So 11 am comes along and my ride from the states finally arrives.
Well i have pics but my brothers pc is junk!!! I will upload them from my house for you all.
Eric
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 09-28-2005, 02:27 PM
Talon69's Avatar
Re: I think i messed up my motor!!!!! HELP!!!
Im home now and still cannot upload pictures,something wrong with this site???
I have pics of the belt also, have a expert here see it and see what they think.
Eric
Current Cars
Old 09-28-2005, 02:42 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
there will be no way to know if the timing jumped a notch by looking at it. you'll have to pull off the covers and make sure the marks are all lined up. you could have very well jumped the belt with all the starting and shutting off you did. belts 99% of the time jump when starting a car so that could have very well happened.
95 Talon TSI AWD
97 Eclipse GST
Old 09-28-2005, 02:46 PM
Talon69's Avatar
If it jumped a tooth are my valves bent? I never heard any noise. Just spit and pop
Current Cars
Old 09-28-2005, 02:55 PM
they may or may not be. i wouldn't turn it over any more at all until you know exactly what the problem is. if the timing is off, each time you turn it over you run the chance of bending vavles and fuck things up worse.
95 Talon TSI AWD
97 Eclipse GST
Old 09-28-2005, 03:03 PM
Talon69's Avatar
Well since i cannot get the photos to upload on the forum here is the next best thing i guess.
http://photobucket.com/albums/b128/1...Picture011.jpg
http://photobucket.com/albums/b128/1...Picture010.jpg
http://photobucket.com/albums/b128/1...Picture003.jpg
http://photobucket.com/albums/b128/1...Picture005.jpg
http://photobucket.com/albums/b128/1...Picture006.jpg
Current Cars
Old 09-28-2005, 03:48 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
your timing would have to be off a couple of teeth before it would do any damage. For your car not to run at all, your timing would have to be way off
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-28-2005, 05:22 PM
not necessarily, 1 tooth and it will sputter and hardly run, 2 teeth and that can do some damage, i still wouldn't even try start it until you find out what's wrong.
95 Talon TSI AWD
97 Eclipse GST
Old 09-28-2005, 05:32 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
A quick check is to take your oil cap off and look and see if you have any rockers that fell off. It's obviously bad news if they are.
Do you know when the t-belt was last changed? Was the tensioner and pulleys replaced too?
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 09-28-2005, 06:14 PM
don't just take off the oil cap and if you can't see any off, think that everything is all good. i would still check the timing belt, but that's just me.
95 Talon TSI AWD
97 Eclipse GST
Old 09-28-2005, 06:32 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Do a compression check. If you have bent valves you will have 0 compresion. If its good, then you might have a CEL code stored in your ecu.
check your MPI and FP fuse. Your pop could have been from to much fuel being shoved in a cylinder from an open Injector.
I would start with the compression, fuses, check all your sensors, plugs, wires, and then move on to your fuel system. Sorry to hear about that. Trucks cost $$
DSM geek
Old 09-28-2005, 06:37 PM
ted_ex's Avatar
ted_ex ted_ex is offline
You can also turn the engine over by hand if you think you might have a valve/piston conflict but if they were damaged you would know for sure because pistons hitting valves makes a bit of noise. Out of curiosity, why do you think it's the timing belt? It could be something dumb like plugs or to much fuel. Hope it's not terminal. And don't go to Canada anymore. Canada sucks.
tedX
I'm>everything
Old 09-28-2005, 06:43 PM
canada is only good if you're between the ages of 18-20...or at least in manitoba cause you can driiiiink.
95 Talon TSI AWD
97 Eclipse GST
Old 09-28-2005, 06:58 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
How does Canada suck? BC, at least, is a great place.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 09-28-2005, 07:04 PM
Re: Re: I think i messed up my motor!!!!! HELP!!!
BC bud baby!
Anyone know how Canada got their name?
Well they wanted a 3 letter name like USA. C'eh N'eh D'eh = cAnAdA
95 Talon TSI AWD
97 Eclipse GST
