Go Back   Automotive Forums Car Chat > Kia > Sorento
Old 09-28-2005, 10:45 AM
KRH KRH is offline
Angry Lights burning out
Hi all,
I'm starting to think my Sorento is possessed. It will be 2 years old this month, and in the last 6 months, my tail end passenger and driver side break lights have burned out several times and my one of my headlights burned out. I had it to the dealership and they could not find an electrical problem. They did say that I shouldn't use 'American' standard bulbs to replace them. I just don't think the bulbs should be going out this frequently. No signs of water damage or anything...and of course light bulbs are only covered for 12 months - nice.
Old 10-04-2005, 10:28 PM
claw1234 claw1234 is offline
Re: Lights burning out
Originally Posted by KRH
Hi all,
Same problem here ,I have had 8 in total burn out...was told by dealer they have a problem with the manufacter and have extended the warranty on bulbs to three years, till they weed them out.
Old 11-07-2005, 09:21 AM
countylinesales countylinesales is offline
I am having the same problem with my sorento with the brake lights burning out, the tail lights still work just the brake light part of the bulb. The right side works on and off, if you apply the brakes it might work or it might not. Most of the time if it does not come on you just lift the hatch and give the lamp a little hit and it comes back on, but not for long. The dealer told me it was a ground wire behind the panels in the cargo area near the jack. If anyone has found the cure or soluttion please post it.
Old 11-11-2005, 10:39 PM
FamilyManOfFive FamilyManOfFive is offline
Talking Planting Bulbs
Have a Kia technician monitor the voltage output of the alternator. Sounds like the voltage regulator is spiking. The weakest link is the filiment in the light bulbs. A poor ground won't do this.
JP
Old 12-14-2005, 09:07 AM
DarrenBaker DarrenBaker is offline
Hi guys,
Is this 3 yr warranty a fact? My Kia dealer has been charging me for the replacement of the lightbulbs (there have been more than a few) for the last year. He gave me the same story about weeding out the bad stock, but that's where it ended. Should I be looking to be recouped for this?
Thanks!
Old 12-14-2005, 11:03 AM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Originally Posted by DarrenBaker
Hi guys,
Thanks!
As far as I know its 12/12 on bulbs. I havent seen anything from Kia updating the bulbs to 3 years. If I find out differently I will let you know.
Old 12-17-2005, 04:20 PM
schultp schultp is offline
Re: Re: Lights burning out
We've had our 2004 Sorento for 2 years. A couple months ago our rear brake lights went out. At first they acted flakey. Then completely out. This was followed by our right front head lamp (low beam). Our tail lights continued to operate (as described in a previous post).
I find it odd that we all are having the same symptoms with our Sorentos! I hope it isn't a wiring issue!
We also lost our clock at the same time. It keeps re-setting to 1:00 whenever we hit the most miniscule road bump. Sometimes it briefly goes black. The dealer replaced it a couple days ago.
We also have intermittent Washer function. It isn't that the lines freeze. They won't work (front or rear) then will operate for a time or two only to stop working a minute later. Washer fluid tank is full. It happens with both the front and back which makes me think it is the pump. This is on order at the dealer.
Any other electrical issues out there? Keep your receipts in case there is a recall in our future!
Paul
Old 02-03-2006, 01:24 PM
BortzKiawv BortzKiawv is offline
Lightbulb Re: Lights burning out
What we found is sometimes brand or install may cause premature burn out in headlights. Rear needs to be 2357 bulbs if sides don't match or incorrect bulbs(1157,2057) used will cause outage.
Old 05-17-2007, 05:41 AM
suyt suyt is offline
also try to be sure the BASE of whatever bulbs are silver NOT brass/copper colored. silver base on headlights and tailights try that.
