Old 09-28-2005, 10:06 AM
gaelic gaelic is offline
95 blazer wont start
i have a 95 blazer 4.3 vortec engine when i try to start all i get is a clicking noise and the instrument panel goes dim my mechanic replaced the starter and it started up but when i switched it off it has refused to start i have tried 3 different batteries all brand new with no luck please help
Old 09-28-2005, 10:23 AM
Cailen Cailen is offline
Re: 95 blazer wont start
Assuming your battery connections are good, I would check your starter solenoid with a load tester.
Old 09-28-2005, 04:30 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Try making sure that all your battery cables are in good condiction. Try moving the cables around. There is a smaller wire that goes from the battery to the starter that broke inside the insulation on my blazer. I just replaced the wire. Don't try and splice it back together. You'll only ask for more trouble later.
Old 09-28-2005, 04:42 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Alternator???
http://jowulf.deviantart.com/
Old 09-28-2005, 05:49 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Most likely your starter was a bad remanufactured.... If all you're getting is clicking, typically it means the starter is bad. Have him fix it again. (You should not be charged)
Old 09-29-2005, 06:29 PM
checked the starter and it worked fine when we took it out but when we put it back in it just clicks
Old 09-29-2005, 06:52 PM
rlith's Avatar
Re: Re: 95 blazer wont start
That really doesn't mean anything. Look at it this way, you have no load on it when it's out of the truck. It takes a lot more power to crank that flywheel than just to spin the bendix. More than likely the starter is too weak to turn the motor.
