It doesn't start properly. sometimes you have to put it in nuteral just to start it! If you don't let it "run" (while giving it light gas) than it stalls! After you get it running it's fine.... Can anyone help me?
Re: Problem w/ probe
is it only when its cold ?
Just because its a honda dosent make it fast ------------------------------------------- 96 gt-ze 2 1/4" magnaflo headers back,short ram intake ,msd,short throw shifter,eibach springs,fidenza fw,clutch masters stage 2,t3/t4 turbo install soon,poly engine mounts ------------------------------------------ www.probesnw.com www.probetalk.com www.mx6.com |
I don't know. So far it has been early morning and late evening when I've tried.
I just bought it a week ago!
probe
to me it sounds like your (iac} idle air control...my sister had one same problem...or u might want to check your 02 sensor also..if it has coil built in distributer it might be weak..but i'd say {iac} from what your telling me...
good luck..... RICK...... |
Do you know what the approx. cost could be? Or what I would tell the Mechanic to get an estimate?
check if your sensor attached to your intake is hooked up.
93 FORD PROBE GT JDM manifold ported match 65mm TB Unorthodox Underdrive Pulley Hotshot headers 3' Exhaust all the way No cat Cold air intake K&N air filter Short throw shifter Eibach lowering springs FX Design Body Kit B&M Short Shifter Stage 3 Clutch MX-3 Flywheel Performace Wires and Plugs Synthetics Performance Rad and fan Mild Weight Reduction Coming this week: Performance Heads and Cams 3 angle head job Why does everyone have to piss on Ford.
Thank you all for replying
my probe is fixed and runs fine!!! |
