Old 09-28-2005, 09:07 AM
HansonHVAC HansonHVAC is offline
Send a message via AIM to HansonHVAC
Door Panel removal
Anyone know how to remove the front door panels on a 91 PA. and what size speakers are in the door? I'd like to replace them with aftermarket speakers.
Old 09-28-2005, 11:05 AM
Holaday1185 Holaday1185 is offline
Re: Door Panel removal
Hey, check out crutchfield.com or etronics.com and click on what fits my vehicle? These websites will assist you in finding out what size speakers your car contains. I also believe that for a small fee, you can order instructions on how to change radio/speakers from crutchfield.com. I think they charge 5 bucks, but if you order from them, they will erase your fee. Good luck, and reply with anymore questions.
Old 09-29-2005, 06:12 AM
volkerc's Avatar
volkerc volkerc is offline
take off the wooden panel that holds the power lock button(1 srew).
lift the black multi switch housing out of the armrest (2 prongues, on at each end) carefully lift it out or you might break something. take out the 2 screws /bolts that are bolted to the door, right below the switch panel you just lifted out. pull out the red plastic lens at the end of the door panel, carefully again, not to break anything. easily done by using a small srewdriver pressed in between the top of the light and the door panel. once that is out, remove the bolts behind that light. now you can pull off the door panel from the door.
