Old 09-28-2005, 08:44 AM
intimidatordei intimidatordei is offline
Tips for Lowering my S-10
I would like to lower my truck (not slam it) a little bit. My truck is a 1994 S-10 extended cab 2wd with a 4.3 Vortec v-6. The rear of the truck sets up about 1 to 1.5 inches higher than the front. Right now I would like to lower the rear and "soften it up" a bit. I do NOT use my truck for hauling at all so I plan to remove the helper from the spring pack. There are three more leafs besides the helpers and I would like to know If I should remove one of these leafs to acheive a final ride height of 1 to 1.5 inches lower or will removing this leaf weaken the suspension too much. As stated before my truck is strickly for show (and possibly a few 1/4 mile passes) and NO HAULING.
Thanks for any help or ideas.
Old 09-28-2005, 10:44 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Lowering my S-10
I'd just try the helper springs first, but don't tighten everything down until you look at it on the ground.
Also try getting some air helper springs, because you will 1 day want to tow a trailer or haul something.
Old 10-03-2005, 11:59 PM
TRACYCULBERSON's Avatar
TRACYCULBERSON TRACYCULBERSON is offline
Re: Re: Lowering my S-10
The simple way would be spend 25 dollars on some lowering blocks they come in 1.1/2 or 2 inch or 2.1/2 or 3 inch blocks. I have used these several times and have had good luck.But if you go over 2inches you may need to look into getting drive shaft cut but 2 inches or less i have never had to .
FAST
Old 10-06-2005, 07:36 AM
I removed the overload springs (that got me about .5 to .75 of an inch) and helped soften up the ride and went with 1 inch blocks to finish it off. That got me where I wanted to be. It's not slammed but looks real sporty. This should improve the hole-shot and lower my ET in the 1/4 mile. Thanks for all your help.
