Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 09-28-2005, 07:06 AM
alwaysmile99 alwaysmile99 is offline
Question reset airbag light
Anyone can help me reset my airbag light on my 2000 VW Passat. Do I need a pin/skc and work shop code? I just bought this car from private, and he cannot find me the key tag for the code. Where else can I obtain the code from?
Thanks in advance !!!!
Old 10-02-2005, 04:14 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
Re: reset airbag light
you need vagcom or VW's scan tool to reset computer no other method available
Old 01-21-2006, 04:53 PM
redtdi96 redtdi96 is offline
try disconnecting + term of battery for a 1/2 hr,then turn on ignition, then connect battery, then turn off ignition (check Bentley on battery disconnect)
Old 02-14-2006, 12:53 PM
Will12 Will12 is offline
If the battery is disconnected, will it erase some of the memory in the computer (I am not too familiar with that)? Will that work, because my airbag light is on, it came on when I was "jamming" on highway and break too hard on the exit ramp?
