Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-28-2005, 06:46 AM
frstwht2gengsr frstwht2gengsr is offline
Unhappy gsr compression
just got my compression done cyl#1 = 140, cyl#2= 145, cyl# 3= 155, cyl# 4 = 152 my car is a 1993 integra gs-r with approx 102000 miles i noticed recently a little smoke out the exhaust around 7000 rpms or close to redline could it be worn rings the car has been dynoed at 130.5 hp and 94.5 lbs tq on a mustang dyno.
Old 09-28-2005, 12:41 PM
Tano016 Tano016 is offline
Re: gsr compression
My 2001 gsr has 240/cylinder, 140 seems low, was it 140 dry or wet?. If you want best results make sure your engine is as warm as possible, make sure your at wide open throttle. For a wet test, pour two table spoons of motoroil through each spark plug hole (one at a time) and repeat the test. If your results increase, your rings are worn since the oil itself is over-sealing the oversized clearence between the ring edge from the cylinder wall, due to worn rings.
Old 09-28-2005, 01:12 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: gsr compression
he is talking about the b17, not the b18c1.
that is low. minimum is 135. max should be around 184. variation should be 28.
though it is low, it still is drivable. i bet it drives like crap.
leakdown to isolate the problem.
consider your options after that.
swap or rebuild.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-28-2005, 03:35 PM
Re: Re: gsr compression
it actually drive fine i my best time at the track was 15.7 last weekend just smokes at full throttle i would like to rebuild it though i hate smoking any suggetions for a economy rebuld and it was a dry compression test
Old 09-28-2005, 07:30 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: gsr compression
smoking on full throttle means the rings are goin on ya!
My 99 GSR has ~210 per cylinder i think it was....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
