Old 09-28-2005, 06:31 AM
motitutty motitutty is offline
Question Changing spark plugs
Hi everybody,
I'm planning to change my plugs and wired soon. I took a glance at the location of the plugs. My problem is, how the heck I can replace the rear plugs, there is barely room to fit a tool.
Any idea or suggestions making life easier? (Besides taking it to a dealer) ;P
'99 3.8 Intrigue
Best Regards,
-M
Old 09-28-2005, 04:03 PM
phewop118 phewop118 is offline
Exclamation
I've never done it, but I've seen 3.8's - you need to rotate the engine forward by about 30 degrees to change the plugs. How you do it, I'm not sure, but there is online info.
Old 09-30-2005, 08:18 PM
Re: Changing spark plugs
Does anyone know how to 'Rotate the engine forward', hopefully without damaging anything?
Thanks,
-M
Old 10-11-2005, 06:34 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
you shouldnt need to rotate the engine forward, i had a series 2 in my Bonneville and changed them with no problems, granted there might be a bit more room with the Bonneville(H-body instead of W) but i wouldnt think you would need to do that.
all i needed to do mine on the series 2 was a ratchet,extension, and spark plug socket, start with the plug socket, then attach the extension then try and get the ratchet in there...give it a shot.
Old 10-13-2005, 06:19 PM
prsoto21 prsoto21 is offline
I changed mine using a long socket, a breaker-bar and vice-grips. It was a little bit of a hastle but worked out fine. Replaced with Bosch Platinum II's and it has been running great.
Old 10-13-2005, 09:40 PM
LittleHoov's Avatar
ive heard horror stories of 3800s and Bosch products, but as long as theyre workin for ya...id recommend OE myself or some equivalent NGKs
Old 10-24-2005, 08:39 AM
2nyce 2nyce is offline
got someone to change mine and it took 2 hrs only paid the dude 30 bones
Old 10-24-2005, 01:20 PM
Re: Re: Changing spark plugs
Hmmm... I would pay someone 30 bucks to do mine... any takers?
-M
Old 10-24-2005, 03:38 PM
harrymay harrymay is offline
does anyone know of any safe and easy ways of rotating the engine? i had a glance at the back of the engine when i changed my tranny fluid und filter, but i couldnt see anything. i would rather rotate the engine so i dont X-thread it.
Old 10-24-2005, 11:46 PM
jmlangeveld jmlangeveld is offline
This is what you need
http://www.autobarn.net/lienti.html
Lisle Engine Tilter. A special tool to used to tilt the engine forward so you can change spark plugs, oxygen sensor, etc. Very Easy with this tool.
Old 11-19-2005, 11:39 AM
caruso81 caruso81 is offline
Re: This is what you need
OK...how in the world does this thing work?!? It looks like it should be painfully obvious, but it also looks too good to be true. I just looked at the rear plugs and thought I'd leave them for a while longer!
Old 11-19-2005, 12:06 PM
DonSor DonSor is offline
I observed someone rotate the engine forward. it was a demonstration by the salesperson at the time when I was shopping for a car. The engine was a 3.8 transverse. All he did was to loosen two large bolts located forward of the einge and right behind the radiator and without a special tool, swung the engine up and forward. I suppose there is some other way to reach the plug.
Caution: some car manufacturers boast that the plugs need not be changed but every 100K miles. If you wait that long, you may find some of the plugs frozen or rusted out in place. Then you got yourself a bag of worms. What I do is "sound" (crack it open slightly and retighten) my plugs every 30K miles or so
as a precaution.
While on the subject, what do you think about replacing single electrode plugs with mulitple electrodes (2 or 4).
