Old 09-27-2005, 11:16 PM
fleshescort fleshescort is offline
weird problem
i have a 93 escort sta.wagon manual transmision 1.9 engine
when i'm drivin my car if i got a hole or a bump in the road it's start making a fail like power or gas and sometimes turn off and i have to turn on again, i already check the fuel pump switch in the rear part of the wagon and everiting look's o.k. it's have a brand new fuel filter ingnition coil sparkplugs and cables and a oxigen sensor
Old 09-28-2005, 06:46 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: weird problem
re read your post hard to figure out what you are saying/asking.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 09-28-2005, 11:50 AM
robertdlouhy robertdlouhy is offline
93 escort
might be the t.p.sensor.
Old 09-28-2005, 12:52 PM
~manuel~ ~manuel~ is offline
Re: weird problem
check your grounds,mainly the battery ground, and for loose connectors.it sounds like there is a loose connection that is internittently making a bad contact when you go over bumps.
Old 09-28-2005, 08:57 PM
Escort_Service Escort_Service is offline
Re: weird problem
take a look at your feul cut off switch. See if its poped up. If your car got bumped in a parking lot it might have set it off. (I had this happen in a friends car.) It was covered in that grease stuff they spray on and did not work properly, so every time he went over a bump it would move and turn the car off.
5.0 Mustang where would you be if I took 4 of your cylinders? In the scrap yard you ugly piece of #$?@
Old 10-22-2005, 07:57 PM
Re: weird problem
I found the problem thank's to everybody who help me
Old 10-22-2005, 08:41 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Can you tell us what you found? I was guessing an ignition switch.
Nevada Tumbleweed
Old 11-02-2005, 04:55 PM
Re: weird problem
it was the fuel injector wiring harness
Old 11-02-2005, 04:57 PM
Re: weird problem
it was the injectors wiring harness
Old 11-04-2005, 11:33 AM
Lynde Lynde is offline
Re: weird problem
It sounds like a loose connection at the battery, or a loose connection at the alternator, check your charging system componets for loosness or excess amount of corrosion. possibly a bad ground wire at the starter.
