Old 09-27-2005, 08:07 PM
phewop118 phewop118 is offline
Question Cracked Wheel?
I noticed a little bubble in the chrome on one of my wheels on my 2001 Intrigue about two weeks ago. I only got it about 3 weeks ago, so it probably has been there from the purchase date. However, when I looked at it today, I saw a small fracture in the chrome in the middle of the bubble. Is this just wear and tear or water or brake dust getting under the chrome and peeling it, or is it a result of a cracked wheel? Could it just be that the previous owner scraped the curb, but didn't damage the wheel? What's all your ideas. Anybody had this sort of problem or had a cracked wheel? How much does it cost to replace?
Old 09-28-2005, 05:50 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Cracked Wheel?
If the wheel is chrome like you said it is probably rust developing under the blister and causing the chrome to crack or split. I doubt the wheel is damaged beyond a cosmetic issue but if it bothers you, you will need to have the wheel either rechromed or replaced. Check the local wrecking yards for a replacement. If the wheel were cracked you will start slowly losing air from the tire. If you are in doubt have the tire removed and check the internal portion of the wheel. If there really is a crack the wheel must be replaced immediately.
Old 11-13-2005, 10:09 PM
The "bulge in the chrome" is now seeming to get worse, at least compared to when I last looked at it last month. It seems to have spread and the chrome has a crack in the middle of the bulge. Also, it isn't soft, but hard, as though the aluminum were bulging underneath it. The tire has no problem holding air, though. If I took it to a local tire shop for a balancing (which I know one of my other wheels needs), could they reliably tell me if it's cracked? If I can, sometime I'll upload a picture.
Old 11-14-2005, 03:06 AM
panzer dragoon panzer dragoon is offline
Re: Cracked Wheel?
there is a GM service note about not using chemical tire (rim or wheel)cleaners on GM chrome wheels or else the chrome starts to peal off.
Use soap and water.
I think with painted rims it doesn't matter.
Old 11-14-2005, 05:16 AM
lunasea808's Avatar
lunasea808 lunasea808 is offline
Send a message via MSN to lunasea808
Re: Re: Cracked Wheel?
Use soap and water.
Yea it does. I have painted wheels. I ruined it by using a wheel cleaner. I don't know if the owner before me took care of the rims. Maybe it was missing the clear coat when I bought the car. Oh well that's just my 2 cents.
Follow me to victory.
We're off to save the hero of the day.
(JAMES HETFIELD)
INOSKEDU!!
Old 11-15-2005, 06:32 AM
Re: Re: Re: Cracked Wheel?
Well that means I'll be looking forward to my rim paint peeling off in another year or two.
Old 11-15-2005, 08:42 PM
I'd say it's just chrome peeling from the previous owner's fault, but there is a hard bubble - it feels like the aluminum is actually bulging. I don't know if that's what it actually is, but it is starting to make me worry.
