Old 05-15-2002, 07:56 AM
liang liang is offline
metallic silver always so matt?
Ive gone over 2 coats on a CLK DTM body, and I figure there is no way I can wet spray the metallic silver ( too thick ). Curiosity got to me and I tried it on a spare ruined body, and damn the thing flooded the lines.
Guiddy, I dug up your porsche 911 GT3 thread, how was your silver finish?
" Increase speed when being overtaken "
Old 05-15-2002, 09:19 AM
Daryl's Avatar
Daryl Daryl is offline
I had that same problem with my CLK-GTR...
That was my first model, and then i couldn't afford clear coat.
Old 05-15-2002, 12:27 PM
Tyrell's Avatar
Tyrell Tyrell is offline
I think you'll find that most (if not all) metallic paints require a *light* rub-down with very fine (1200) wet'n'dry (note: light rub-down, not to the plastic again ), then a few coats of clear lacquer.
This gives you a nice, shiny finish that's just right for decalling...
Regards
Mark
Current Project:
Old 05-15-2002, 05:50 PM
primera man's Avatar
"P-Man"
Metallic colors always need more work to get a good finish.
I give mine a good rub with pubbing compound to get a good finish.
You still never end up with a nice deep gloss though
View All My Models Here.
Old 05-15-2002, 09:40 PM
ok today I tried rubbing on the roof after sanding 1200grit. result was lousy with a darker shade of grey rather than silver met.
I guess I will have to settle with lacquer finish with exterior gloss ( no inner coat reflection so no mirror effect ).
Old 05-15-2002, 10:01 PM
The Cougar The Cougar is offline
Send a message via AIM to The Cougar
Just be sure not to clearcoat that particular coat of paint. That "dark grey" area you're talking about is staining, I think. I've had that happen a couple times. It won't go away with clearcoat.
Hope I could help.
-Coug
Old 05-15-2002, 10:04 PM
a little help beats no help at all.
I'll be respraying b4 clearcoating. that was just a test rub.
Old 05-17-2002, 02:57 PM
daggerlee's Avatar
Don't worry about the darker grey spots. It means that 1200 grit was flatter than the original paint coat. (like flat red looks darker than gloss red) It'll go away with the clear coat.
Dan
