Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 09-27-2005, 11:14 AM
grodrianst grodrianst is offline
Send a message via AIM to grodrianst
Need help to tighten loose steering wheel
Hey All,
86 G body tilt steering is loose and wheel wobbles all over. After searching the forums found out that loose bolts were the problem. I have the column tore down to where I can see the three bolts but can only get a socket on one of them. There is a big gray metal part where the ignition switch actually is and where the steering rod actually goes through that is in the way. Does this come off somehow in order to tighten the bolts? It almost looks like the bolts actually go through this part but I can't tell for sure. Hayne's and Chilton's little help in tearing the column down past this point.
