Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 05-14-2002, 11:57 PM
shrubchild shrubchild is offline
Send a message via ICQ to shrubchild Send a message via AIM to shrubchild Send a message via Yahoo to shrubchild
Question Spec V Top Speed?
anyone know?
Old 05-15-2002, 08:31 AM
muphasta muphasta is offline
Send a message via AIM to muphasta
From what others have posted here, and what I've read in the mags, it sounds like 135-138 w/the rev limiter in place.
I had mine up to 115, and it felt smooth and stable. No shimmy, no shake, nothing to make me uncomfortable. Well, other than fear of a ticket!
Old 05-15-2002, 11:57 PM
how fast you think it could get up to with the governer taken off but otherwise stock?
my guess would be 147 but im hopeful for over 150
Old 06-09-2002, 03:40 PM
SER Speedalot SER Speedalot is offline
my friend hit 145 stock. the fastest i've gone in mine is 135. these cars scream.
Cam'ron
Old 06-15-2002, 10:21 AM
JAvidan JAvidan is offline
First day I got my Spec I went on I-95 got this beast up to 136 mph. It had 9 miles on it and I know you're not supposed to do that shit until 500 or so miles, but once I drove it off the lot I had to see what it could do. I think with an Injen cold air and a stillen catback I could get this car up to 150 (w/o the govenor of course).
Jon
(if anyone needs shit for their cars, I ship all over the US. go to www.bestbuyus.com. Thats my store and we're right outside of Philly)
Old 10-22-2004, 02:08 PM
doke87 doke87 is offline
Re: Spec V Top Speed?
My 02 Spec V governor kicked in at 122MPH in 5th gear at 5800rpms, then i shifted into 6th and it sat at 4800rpms at 122MPH still.
Old 10-24-2004, 09:45 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
there is no governor, it's drag limited
if you hit a "top speed" where it won't accelerate anymore, that simply means that your car doesn't have enough power to go any faster. I repeat, there is NO governor/speed limiter on the b15 sentra. The only thing to limit your top speed is the rev limiter itself, but in the top gear that won't kick in to about 155.
A stock spec tops out around 135, if you've gone faster that simply shows the inaccuracy of the stock speedometer. Take a GPS into your car and try again and you'll see.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-24-2004, 11:21 PM
pacificblue200 pacificblue200 is offline
There's no way a Spec will do 145-150. 135 at the most, you have to realize that speedos can be off by ton at those speeds.
Old 11-02-2004, 08:40 PM
GB Phoenix77 GB Phoenix77 is offline
When I had my spec V the most I saw was 135 on my speedo.. but, speedo's are typically off by around 5 to 10 percent. So in reality probably around 125 or so.
Old 11-07-2004, 02:05 PM
daveshapellSVT's Avatar
daveshapellSVT daveshapellSVT is offline
Specvgini
Yea i think 130-135 sounds accurate.. i personally have done 122 in mine and it felt like it had more to go, but it was taking too long so i was like eh forget it.. i don't believe there is a governor either. i mean if you have the time and road i bet the car can get up to 140, but it takes such a long time..
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
Old 12-22-2004, 03:37 PM
nudelude nudelude is offline
im my '95 prelude Si my top speed was higher than an '02 Spec V that i raced. we were on I-95 and we both floored it and several times i would pull ahead of him. at that point i remember seeing about 125-127 on my speedo. my car was stock and im pretty sure his was too.. so i don't think the '02 Spec V's went any higher than 125-130 max.
Old 12-25-2004, 02:04 PM
Specvgini
lets put it this way.. my civic hatch is stock and only has 108 hp, and i've had that thing up to 120 before... I'd bet money that the spec v can max out at 140+...
Old 12-26-2004, 08:27 PM
Nipz Nipz is offline
stock spec-v top out at 130-140. I have had mine 142 with hotshot CIA, stillen header and DP, MM, and N1 ex. stock i hit about 132-136. when i hit 136 it was down hill a bit. .
Nipz~
Old 12-27-2004, 11:28 PM
Specvgini
oh sweet, you get dyno'd yet? what do u run at the track?
Old 12-28-2004, 12:42 AM
have not dyno it ye or taken down to the track. I work the days the track is open
Nipz~
