Old 09-27-2005, 02:44 AM
89ZCCivic's Avatar
89ZCCivic 89ZCCivic is offline
radiator fan?
Is the radiator fan supposed to stay on after you turn off the car,couse mine does it just strarted doing that ever since i cleaned my motor.i do remember covering up all the electrical parts
Old 09-27-2005, 07:52 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: radiator fan?
As far as I know the fan should only run when the key is in the run position. You probably got some water in the relay and it's malfunctioning or the temp sensor got messed up. GL
Old 09-27-2005, 10:32 AM
Smoghog Smoghog is offline
Re: Re: radiator fan?
There should be a sticker on the radiator that says "radiator fan comes on automatically" Or something to that affect.
It probably runs just after you turn off the car and runs for a couple of minutes.
It is suppose to.
SH
Old 09-28-2005, 08:01 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
Re: radiator fan?
i dont think mine ever ran after i shut the car off, but never paid much attension to it to see if it does or not, just takes longer to come on since i put the alluminum rad. in.
The Evil Sleeper
Old 09-28-2005, 08:04 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: radiator fan?
nope... supposed to shut off when car is off.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-29-2005, 05:17 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
Re: radiator fan?
Acually the fans will stay on after you turn off the key if your car is over heating, But since you washed your engine bay you probably got the connector wet and its stays on after the car is shut off any way, this happend on my bro's accord after he washed the motor.
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 09-29-2005, 07:35 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: radiator fan?
i hooked up mine to stay on all the time ...its just a jumper wire...it turns off with the key...its never stayed on when the car is off...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 09-30-2005, 08:00 AM
Same here...
2010 Honda CR-V EX
Old 10-01-2005, 12:45 AM
DTangent DTangent is offline
How long does the fan stay on?
Anyway, disconnect the fan connectors (two of them) and clean them out. Make sure the o-rings are good. Coat the o-rings with a little oil, then reconnect. Disconnect the fan relay and clean out as well. Pack it with electrical grease then reconnect. If the problem was caused from washing your car, that will fix it.
Old 10-02-2005, 10:22 PM
honda_luvr_2000 honda_luvr_2000 is offline
Re: radiator fan?
anyone ever look at a cooling fan circuit diagram?? bet not for those of u that say it is supposed to stay on after the car is turned off. it's control is only hot in run, not hot at all times. so to answer u'r question, no it isn't supposed to stay on after u turn off the car. yes u must have gotten sumthin wet during the wash, and possibly in time it'll be back to normal.
Originally Posted by Greenblurr93
ahh i see said the blind man to his deaf wife, as he pissed into the wind, its all coming back to me now.
