Old 09-27-2005, 12:08 AM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Griffin Intercoolers?
Hey guys, does anyone have any opinions on Griffin Intercoolers? I was lookin around RRE's site, and those intercoolers seems pretty nice. DSM tuners has some info on them, but not much.
http://www.roadraceengineering.com/intercoolers.htm is the link.
I'm looking at the 24 x 10 x 2.75 side to side flow with the endtanks welded on at the offset position. Only $400. It LOOKS good, but how does it perform? I don't really know how to read RRE's flow charts on the core.
Thanks guys.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 09-28-2005, 10:12 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Griffin Intercoolers?
Seems decent, my brother (ted-ex) bought an intercooler from ebay and it is amazing quality and was like $250. btw it's 24x12x3. Here's one http://cgi.ebay.com/ebaymotors/HUGE-...QQcmdZViewItem
not the same seller but looks similar. On an intercooler i really don't think there is that much to messs up. I could be wrong, but it's not a mechanical part so i think it would be fine.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-28-2005, 10:17 AM
ez1286's Avatar
Also i was just thinking about this, those top to bottom intercoolers seem really inefficient. The air would take the path of least resistance, so like half maybe less of the intercooler would be used.
Old 09-28-2005, 11:16 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Might want to watch that one if you ever plan on running higher boost. It says it's only designed to hold up to 25psi.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-28-2005, 11:22 AM
Here is the whole thing I don't understand about FMIC's. You can get a core off ebay for about $200 shipped to your door, right? Most people say that you need 3 "U" bends, one piece of straight pipe, 2 or 3 couplers, a couple of worm clamps and a BOV flange. Cut the pipes in the appropriate place, weld on the flange and you are done. I'm sure it's not that easy to install, but you get the gist.
Anyway, everytime I see a complete kit, the damn thing is about $1000. WTF. Are worm clamps and "U" bends that expensive.
If I every fabricate my own pipes, I swear I'm going to start cranking out copies and selling them on ebay for $100 less than everyone else. I'm sure I could make a killing.
By the way, while we are on the subject of FMIC's, does anyone know how bad it would be if you just ran the piping over to where my UICP is now (off the stock SMIC location?
1997 Spyder GS-T
5-Speed
Old 09-28-2005, 12:04 PM
Well, I emailed RRE and they said that that core would be plenty effiecient for an evo3 16g, and that I prolly won't have to take out the stock fog lights.
Seems like a good deal. I'm most likely going to get this core for Chanukah! Wooo
Old 09-28-2005, 05:23 PM
tsi4444 tsi4444 is offline
When I installed my jrc intercooler all i needed was a u bend and a 90 degree bend from summit. I used the 90 degree bend to go from the intercooler up to my brode uicp and i only needed to cut like an ninch or two off to make it fit.
97 TSI AWD
Apexi N1
RRE Downpipe w/test pipe, K&N FIPK, RRE lightened flywheel, ACT 2600, New short block installed due to crankwalk,autometer sport comp boost gauge,type-s bov, brode uicp, Johnny race car fmic with custom piping, evo 3 16g
Soon to be purchased: DSM link, injectors, fuel pump
Old 09-28-2005, 06:36 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Re: Griffin Intercoolers?
To late, its called OBX. I emailed that seller about 3 weeks ago and asked if that 25psi was a mistake. It's not. There are plenty of bar and plate intercoolers that will flow 800-1000cfm with 1.5psi drop for about $200-250 shipped. I was on their like i said a few weeks ago shoping for one.
Ps. Side to Side intercoolers make air pass through more surface area to cool the air. Example 2 and 3 (griffen rre) will provide the best results. Top to Bottem Intercoolers are the best becasue their is less chance of heat soak and are typicaly the most effecent intercoolers with lowest pressure drop. thats why they are more expensive
DSM geek
Old 09-30-2005, 09:33 PM
ez1286's Avatar
Re: Re: Re: Griffin Intercoolers?
They have less pressure drop but at what expense? It just sees like the air wouldn't flow through the entire intercooler. Wouldn't that result in less cooling efficiency?
BTW: I made my own intercooler piping from exhaust piping, i welded as many seems as possible and it cost like $50 total (piping only). I think the reason piping kits cost so much is cause they use aluminum piping which for some reason costs more than steel piping (steel cost>aluminum cost, steel pipe cost<aluminum pipe cost )
Old 10-01-2005, 11:13 AM
Will I see any gains, or losses if I put it on right now without upgrading the turbo? I don't want to get it, then have it slower than before putting it on
