Old 09-27-2005, 12:58 AM
bones91's Avatar
bones91 bones91 is offline
Angry fixed speedometer now gas gauge aint working
ok i posted earlier that my speedometer wasent working so i took my whole dash off and check out the speedometer and after that nothing looked wrong so i put it back together so after doing that i took it for a test drive and my speedometer worked fine but now my damn gas gauge aint working any onr know what the problem is??? and do u think the yellow light will still turn on (when im low on gas) even thow my gas gauge aint working?? plz help thanks
Old 09-27-2005, 09:10 AM
powerplating's Avatar
powerplating powerplating is offline
Send a message via Yahoo to powerplating
Re: fixed speedometer now gas gauge aint working
Im thinking you need to go back in and check all the connection
Good luck
Jim Eaton
27 Years Plating And Polishing
479-639-2575
http://www.geocities.com/powerplating/
Old 09-27-2005, 01:45 PM
mpumas mpumas is offline
Sounds like a connector problem in both cases. The gas gage signal and the yellow light signal come in on different wires. So you won't know unless you short the light wire to ground at the tank. It is the green/red wire. By shorting the yel/wht wire to ground, the gas gage should go to full. The black wire is ground.
