Old 09-26-2005, 11:32 PM
traderp traderp is offline
95 Blazer warms up and shuts off..help
I have a 1995 S-10 Blazer 4.3 Vortec 4X4....When the motor warms up is starts sputtering and then shuts off. When i try to restart it will not run. When it cools off itg will run again but only few minutes until it warms back up. I am not getting any codes on a scanner. Fuel preasure is 60psi right where it needs to be and when i turn it over after it shuts off it gives me good spark....any ideas
Thanks for youalls help
Old 09-26-2005, 11:55 PM
drdd's Avatar
drdd drdd is offline
Re: 95 Blazer warms up and shuts off..help
what is your battery voltage? when engine is running? when ign on but not engine running?
when is the last time u had your fuel filter changed?
report back ...
Old 09-27-2005, 08:14 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Same thing happen to my '93. It was the Ignition Module in the distributor. If you remove the Distributor cap and rotor, all you have to do is remove the two screws and un-plug the harness clips to remove it. Some Autozone stores can actually test the Module OUT of the truck. When I replaced mine for approx. $35 USD, the problem was solved.
Oh and BTW, Don't let the counter help tell you that ignition modules either work or they don't, or that heat has no effect on them because if they tell you this, (A) they're full of crap, and (B) they don't know what they're talking about. I have had to replace the Ignition Module in my 93 twice and both times it did what yours is doing (Heating up and shutting off) and both times replacing the module was the fix.
