Old 09-26-2005, 10:29 PM
ted_ex's Avatar
ted_ex ted_ex is offline
.25mm cut crank
So I'm about 2 seconds away from putting my engine back together and I ran into another problem. I have a cut crank (.25mm) and I realized I don't have the rod bearings. Not a big problem. However, I don't know if the rod bearings need to be .25mm oversized or not. I sort of assume they will be but I'm not sure. Before I buy the wrong bearings someone answer this question. Are the rod journals on the crank cut to the same specs as the main bearings typically or am I going to have to find someone with a micrometer to actually measure them? Damn I suck.
tedX
I'm>everything
Old 09-26-2005, 11:11 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: .25mm cut crank
yes my son
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 09-27-2005, 05:05 PM
ted_ex's Avatar
Re: .25mm cut crank
I knew you were gonna put something stupid tard-fucker. Anyone who has a 3 digit IQ?
I'm>everything
Old 09-27-2005, 05:12 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: .25mm cut crank
well which journals did you get cut? did you get the main and rod's or just the rods or just the mains? whoever cut the crank should be able to tell you which journals were cut or not. you might be able to tell by looking at them which ones were cut and which ones were not. anyways, which ever ones were cut, you will need to get .25 oversized bearings.
95 Talon TSI AWD
97 Eclipse GST
Old 09-27-2005, 06:22 PM
ted_ex's Avatar
Re: .25mm cut crank
I bought a reman crank because mine was destroyed. It came with oversized main bearings but didn't say anything about the rod bearings and obviously didn't come with the rod bearings so I'm not sure if they were cut.
I'm>everything
Old 09-27-2005, 06:40 PM
MexRocket's Avatar
Re: .25mm cut crank
why dont you just call the place the sent you the reman crank?
Old 09-28-2005, 09:57 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Re: .25mm cut crank
Originally Posted by MexRocket
why dont you just call the place the sent you the reman crank? Also i suck cock all the time
Thats just sick.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
