Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 09-26-2005, 08:07 PM
k_dawg k_dawg is offline
Injector rings
I have a JDM B16A engine in my integra. I bought some DSM injectors for the engine but when I put the stock rings on the new injectors, they do not fit back in the slot. The new injectors have a bigger diameter and the rings stretch when you put them on the injector, causing the injector not to fit back down the hole. What should I do? Different injectors, different rings?
Old 09-27-2005, 07:12 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Injector rings
you talking about the top or the bottom ring ?
Team Lonely Drivers
Old 09-27-2005, 12:55 PM
I am not talking about the o-ring but the big ring at the bottom. The big thick one.
Old 09-27-2005, 01:07 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Injector rings
use the honda rings on the upper. dremel the bottom honda rings until they fit.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-27-2005, 01:08 PM
AF - Advisor
Re: Injector rings
try this.
http://www.geocities.com/speed_phreak_88hf/how2dsm.htm
Old 09-27-2005, 02:37 PM
Will that cause fuel to leak out the ring or no. Doesn't that keep the pressure inside. I do not know
Old 09-27-2005, 04:03 PM
AF - Advisor
Re: Injector rings
you see how snug the oem honda injectors fit in the oem rings. well, dremel it till it feels the same way with the dsms.
