Old 09-26-2005, 07:07 PM
almostfinished almostfinished is offline
Send a message via AIM to almostfinished
What size wheel
Hey guys, I'm gettin a 2002 silverado 2500 hd with the 6.0. I have a set of 33x12.5x15 bfg's from my old bronco that I wanna put on this truck. I was wondering if anyone makes a 15 inch 8 lugger preferably black and if so, will they clear the calipers. I was thinkin of just a plain, hole type wheel. Any suggestions please email me or respond. thanks. Oh and if anyone can give me a heads up on the truck and if there are any big problems with them. thanks
Nick
[email protected]
Old 09-26-2005, 08:17 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
Re: What size wheel
Nick
[email protected]
congrats on the new truck. i have never seen any 15 inch wheels on a new truck. i dont think they will fit, but them might.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 09-26-2005, 08:26 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: What size wheel
On the HD you will have to clear the brakes..... I don't think your 15's will make it. Sorry
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 09-26-2005, 09:42 PM
Rollingbones's Avatar
Rollingbones Rollingbones is offline
Re: What size wheel
I would also be willing to bet the bolt pattern/size is off as well!!!
2002 Superado, LT (Carmine Red), 5.3 L
3.73 RR, Flowmaster, K&N FIPK Cold Air Intake,
160 T-stat, Hypertech Tune, Towing Pkg.
More pics here: http://www.cardomain.com/ride/2091584
HAVE A NICE DAY...
...Unless you have other plans!!!
Old 09-27-2005, 04:32 PM
Cool, thanks guys for the responses. I bought the tires for my bronco last dec and they have about 5k on them so they are like near new. I was gonna get some 15" black wheels, I thought it would look good with the white exterior. I guess I'll have to sell the tires and get some in 16". Just for kicks, does anyone know the max size I can run on the truck without rubbing issues? And do I have to reporgram for the speedo or anything else? Thanks again.
Nick
Old 09-27-2005, 04:42 PM
Re: What size wheel
Nick
ive seen 33's run with no lift and have only minor rubbing at full turn. and the speedo can only be fixed with a hypertech or similar programmer.
Old 09-27-2005, 08:02 PM
jethro_3's Avatar
Re: What size wheel
Check the label in the driver door frame for the origonal tire/rim size. Some of those HD's came with 17's as stock.... Those bigger brakes don't fit in 16's... My custom 18's from my '01 won't fit on my '05 with the 17" brakes...
Old 09-28-2005, 11:38 AM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
I'm having to shave my rear calipers down about an 1/8" to fit my 15x10s. There just aren't enough slick options for 16s.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 09-28-2005, 12:03 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: What size wheel
Nick
You don't have to reprogram unless you want the speedo to be accurate. It won't be off by much.
As for the tire sizes, a 285/75 is the same diameter as a 33, but slightly narrower. They will usually fit without any modifications. If you want to make sure they fit you can crank the t bars about 4 rounds.
305/70's will fit, and are the same size as a 33.12.50/16. They will rub a little, so cranking the bars is ususally necessary. If you plan on using any rim wider than 8", the tires will sometimes rub on the inner fenderwell and the lower bumper valance at full turn. Stock Wheels should do fine.
My buddy's '01 2500HD had 285/75 and 16x10 Weld's on it and they hit BAD! We had to trim the hell out of the bumper valance and also some more inside the fender....it jsut depends on your backspacing.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 09-28-2005, 04:31 PM
Awesome, thanks guys for the quick replys. It has fairly new tires on it already but I'd like to change em to a bigger size some time down the road. I can't wait until tomorrow when I get to pick this truck up and never have to see my old money pit bronco again.
Nick
Old 09-28-2005, 05:26 PM
jethro_3's Avatar
Re: What size wheel
A new convert.... Don't we require them to start a new thread called "I'm the newbie!!! Hello ?"
Jokes, welcome ...
Cam in and
Check out my Ride
Old 10-02-2005, 09:17 PM
WOLFIE1961 WOLFIE1961 is offline
Re: What size wheel
Nick
[email protected]
I just put a set of 285/75/16 on my '02 2500HD. I have the bar cranked to level it out. I had to trim a little of the front plastic valance in order to clear. I don't think you can go much bigger than that without a lift.
Old 10-02-2005, 09:26 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: What size wheel
I recently changed wheels/tires on my truck, and was curious as far as what the different measurements mean. when I had everything off the truck, my new wheels/tires sat about an inch higher than my old ones. Here is a good link to explain the numbers for those of you who, like me, are clueless on tire sizes:
http://www.discounttiredirect.com/di...Dimensions.jsp
All I know is that little bit of difference threw my calculated MPG from over 14 MPG city to just over 11 MPG city. I am not sure exactly how much my speedo is off, but it's obvious it is. I already emailed Allen to see about corecting the PCM for it, and he said no problem.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 10-03-2005, 06:43 PM
jeverett's Avatar
Re: What size wheel
Im about to put 285s back on mine to get a tad bit better mileage when cruising
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 07-23-2007, 11:52 PM
rm125kid2002 rm125kid2002 is offline
Re: What size wheel
i have 33x12.5x15 that were on a k5..... you think they fit my 2001 1500 z71?
