Go Back   Automotive Forums Car Chat > Mitsubishi > Aspire
Old 09-26-2005, 05:55 PM
massey0412 massey0412 is offline
Unhappy heating prblem 2002 gallant
I have a 2002 gallant.First I noticed clicking noise when I changed the setting from hot to cold or put defrost on.Now the heat only blows cold air and doesnt get hot.Has anyone had a similar problem and could it be the thermostat.The car does not overheat,could the thermostat be stuck open?
Old 11-15-2005, 03:58 PM
mazdatech177 mazdatech177 is offline
Re: heating prblem 2002 gallant
it sound like the blend door or cable or rod has come loose in your hvac box. sould see something by removing glove box and looking new center console.
Old 01-07-2006, 01:03 PM
SLoe's Avatar
SLoe SLoe is offline
Yes it could very likely be the thermostat stuck open.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 05-28-2006, 09:50 AM
BigRed BigRed is offline
same here...its a blend door problem. It looks like the entire a/c /heat contol box has to be pulled to get to it. Its sounds like its behind the center vents. I pulled radio, hot/cold, fan, etc. thats below radio and nothin wrong. Hayes has a good pix on 3-11. Ill scan and send to anyone intrested. I dont know if a pen fell down into the vent jamming the door or what. keep this thre ad alive.
Old 08-24-2006, 11:44 PM
chester08 chester08 is offline
Banned
If the blend doors are the problem, turn the blend door from air to heat and leave it there. Search for the door mechanism that moves the door back and forth. That's the one that needs to be moved and left in the heater position.
