Old 09-26-2005, 05:32 PM
mark01070 mark01070 is offline
Left Blinker
My left blinker in the front and back both work but i manually have to use my hand to have them blink...my right side works perfectly...I hear the clicking noise... so I thinik it is not the flasher in my car or neither would work i'm thinking.......maybe its the wiring....any help I would appreciate it
Old 09-26-2005, 05:38 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
Re: Left Blinker
what do u mean manually have to use your hand?
I just fixed mine, replaced the flasher unit and replaced the light socket. It was the light socket that was bad though, it catches extra heat from the engine compartment that the right one doesnt for some odd reason. Take it off and look at it if its burnt up pretty bad you need a new one.
Old 09-26-2005, 05:40 PM
Matt365's Avatar
Re: Left Blinker
oh and btw, IF that doesnt fix it, it means u have a bad ground. There really no easy way to fix the bad ground. You can either A. find it and fix the problem at the source. B. Rewire the whole ground to it. Im pretty sure theres a way to run a seperat ground, but im not sure on it, maybe someone else with more electirical experience can help u with that one.
