Old 09-26-2005, 04:50 PM
doughboy_customz doughboy_customz is offline
AWD to FWD conversion questions
Does anybody know what all i would have to do to convert and AWD talon to a FWD talon? and if your wondering why i'm doing it. I cant afford an AWD tranny but i found a functional FWD for a decent price.
1989 honda prelude 2.0 Si
custom painted interior
dressed engine bay
short ram intake
2.25" catback exhaust with magnaflow muffler
in the process of building turbo kit
Old 09-26-2005, 05:25 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
That would be like taking the nuts off a bull, and replacing them with marbles. AWD is an edge that should be utilized, not stripped away. Save up for the AWD tranny.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-26-2005, 05:52 PM
Black97GST Black97GST is offline
Re: AWD to FWD conversion questions
yeah.... seriously you will REGRET switching it to FWD instead of keeping it AWD. Wheel spin is a bitch.
Old 09-26-2005, 08:25 PM
civicblumagik021 civicblumagik021 is offline
Send a message via AIM to civicblumagik021
wtf?? awd to fwd?? i must be lost
TSi awd turbo-fast as hell!!!
5spd
evo III Big 16g
HKS super sequential BOV
Apexi N1 catback
Apexi Turbo timer
K&N intake
*DSM Powered*
Old 09-27-2005, 04:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
I'll agree that this move ould be bizarre, but to answer the question, I can't think of anything else that would have to be changed. I see good shifting 1g awd trannys for 300 all day long, so I am assuming you mean 2g (more like 5-600). You'l obviously want to remove the driveshaft.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-27-2005, 11:23 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Wouldnt the rear dif need to be removed? Wont it just get damaged because its just dragging?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-27-2005, 12:12 PM
could you get me one for that then cause theres only one salvage yard around here that has an AWD and he wants 500$ for it BTW it is a 1g
dressed engine bay
short ram intake
Old 09-27-2005, 04:13 PM
david-b's Avatar
Dave is THAT guy
Please
ENGLISH!!!
75 Monte Carlo
Old 09-27-2005, 04:16 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
he wants kevin to find a awd tranny for 300. look on ebay and if you find one take your salvage yard the ebay quote and they might give it to you for that uf you cant do that just buy one off ebay.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 09-27-2005, 09:24 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Just leaving the rear end back there would be ok I think (not sure). Converting the rear end and the FWD tranny would cost more than just saving and buying an AWD tranny. You should be able to beat $500, I would either save up or hit eBay.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-27-2005, 10:00 PM
macder macder is offline
Send a message via MSN to macder
AWD tranny's for 1g's are usually only $100 - $200 more expensive then a FWD one. If you think about, converting a AWD to a FWD would cost more then just buying an AWD tranny. Unless you plan on doing the work yourself, and selling your AWD parts then maybe you can save couple hundred dollars. This has to be the most bizzare conversion I've heard of so far, soon someone is going to want to make their turbo a NA.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 09-27-2005, 11:18 PM
Re: Re: AWD to FWD conversion questions
The shotgun is locked and loaded for when the time comes.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-28-2005, 07:18 AM
AF - Advisor
Poeple NT thier cars all the time. For new motor breakins though
I don't see how leaving the rear diff in will hurt anything, it will sping freely and has its own oil supply, etc.
Just realized that you will have to swap the flywheel and starter plate too, those must match the tranny, and AWD and FWD are different diameters. Clutchs are the same however. And I still don't condone this behavior, just trying to help
Kevin Jewer
Old 09-28-2005, 12:39 PM
hmmm if im going to have to change the flywheel and everything i might just try my best to find an AWD for it. i've gotta buy a clutch anyway its tore out of it thanks for the help guys.
dressed engine bay
short ram intake
Old 09-28-2005, 01:19 PM
david-b's Avatar
Dave is THAT guy
^^^ He's seen the light! Good job guys. Our work is done here. And whats wrong with NT their turbo car? Nothing IMO!
75 Monte Carlo
