Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-26-2005, 03:56 PM
pinkslipRT pinkslipRT is offline
Banned
got a question bout pistons
can je pistons be pressed onto the stock rods?
Old 09-29-2005, 04:50 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: got a question bout pistons
Yes! Why not go with some Eagle or Crower rods though?
Old 09-29-2005, 05:21 PM
Banned
Thats Why I Was Asking About The Hp Ratings Of The Stocks In The Other Thread
Old 09-29-2005, 05:50 PM
TEXSRT4 TEXSRT4 is offline
stock PT rods arnt the best. the SRT rods are handling more than 600hp. the problem is that they fatigue at high rpm. if your building a road race car, or the like, you will want to change them out before they stretch or bend
Old 09-29-2005, 05:58 PM
Banned
no this is just the normal dohc neon rods in this one,and will the srt4 rods fit in this block..........................ps tex im building this one myself on a limited budget it not the same as in our neverending bs thread that i didnt take much part in building
Old 09-29-2005, 07:13 PM
ok. its a differnt crank, meaning that the rod length is differnt. you can pick up any number of good rods for the dohc neons. they are out there. JE, Eagle, SCAT. all depends on how much power your looking to make
Old 09-29-2005, 09:29 PM
Banned
yes i knew what was available, i just thought you in your above statement thought i had the pt motor in this one. i am going about 225 without spray between 275 and 300 with spray do you think stock rod will hold before spray/after spray, i do understand its mainly on how often i spray. but i just dont know these rods that well
Old 09-30-2005, 08:38 AM
Re: Re: got a question bout pistons
The following quote is from Hahn Racecraft's website:
"Even in its current 600HP configuration, this Neon is still street driven. And, perhaps even more amazing, it's engine is still mostly stock, with the exception of forged pistons and billet connecting rods. The completely stock cylinder head has never been disassembled in 45,000 miles of use! We resisted other mods to the engine in order to establish the durability and power potential of the stock components. Doing so also demonstrates the power adding capability of the bolt-on HRC TurboSystem on a mostly stock, inexpensive engine."
They are using aftermarket rods on a 600HP neon, so I think the stock rods would hold 225-300HP
Old 09-30-2005, 04:27 PM
1stGenRT 1stGenRT is offline
Banned
formally known as pinkslipRT
ok cool i hope so anyway but in that motor you quoted the only thing they did replace was the rods and pistons so that will be my path
Old 09-30-2005, 04:52 PM
Sounds like a good plan!
