Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-26-2005, 02:11 PM
Jimtilli Jimtilli is offline
Question 1999 Chevy Tahoe fuel/starting problems
I own a 1999 Chevy Tahoe 4x4 LT with a 5.7 liter engine. I replaced the fuel relay two months ago and this solved my starting problems. Then a month later it wouldn't start again and I replaced the fuel pump with an AC Delco fuel pump and also replaced the fuel filter. It started and ran well for a month until the this last weekend. (September 24,2005). The vehicle wouldn't start for 24 hours. The day before it happened also but was only a few hours between starting. Each time it was re-started, you could shut it off and restart it multiple times without a problem. The vehicle has 104,000 miles on it and runs great besides this issue. Anyone have any ideas or suggestions on why this may be occuring?
thanks!
Old 10-01-2005, 10:02 AM
TRANSFORMDEZIGN TRANSFORMDEZIGN is offline
Re: 1999 Chevy Tahoe fuel/starting problems
thanks!
I'M THINKING MAYBE A PINCHED OR GROUNDED OUT WIRE FOR THE FUEL PUMP. (I'VE SEEN THAT HAPPEN A COUPLE OF TIMES)MAYBE FUEL PRESSURE REGULATOR. OR SOMETIMES THE BOTTOM OF THE RELAY
BOX COULD NO BE MESSED UP.
Old 10-01-2005, 10:50 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
A couple things could be going on here and it sounds like a loose connection.
Check the wire that runs from the battery to the left underhood fuse box, if it is loose or corroded, this could cause the concern.
The main thing is you need to determine what is missing when the truck wont start (fuel or spark)
Also check the wires going to the coil, I have seen them break inside the insulation and cause an intermittant no start.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-03-2005, 01:15 AM
decoy86 decoy86 is offline
Re: Re: 1999 Chevy Tahoe fuel/starting problems
I had to replace my battery cable that goes from the battery to the fuse box a month ago on my '99 Tahoe. It was heavily on the corroded side- Even a foot up the cable. $50 at the dealer..
Old 10-16-2005, 10:27 AM
marvin19 marvin19 is offline
thanks!
You might want to check the fuel pump connector. I have a 97 tahoe and i replaced the fuel pump twice in two months just to find out the fuel pumps were good and the connector was bad.
Old 12-15-2005, 07:10 PM
kjf1969 kjf1969 is offline
I did the same thing. I replaced two fuel pumps and found out the coil connector to the pump had eroded away and the wiring was bad. Once replaced it ran fine.
