Old 09-26-2005, 01:51 PM
godsbail godsbail is offline
Unhappy help
does anyone know why that a 1995 ford windstar van dies while going down the road. you can wait a little while and it will crank and run for
who knows how long than it will do it again. please help.
Old 09-26-2005, 02:06 PM
DRW1000 DRW1000 is offline
Re: help
Is your 95 OBD11 compatible? Some 95s are. IF so is your Check Engine Light on?
Old 09-26-2005, 02:52 PM
Re: help
no the check engine light is not on.
1995 ford windstar van just dies. and you can wait a little while and it will start back.
Old 09-26-2005, 03:27 PM
Re: help
Does the light work? (Does it illuminate momentarilly upon start up)?
I am fairly sure that the 95 Windstars are OBD11 vehicles. Is it a 3.0 or 3.8L? One may be OBD11 and one may not be. I think the one I read codes for a coworker was a 95 3.0L and it was OBD11.
If so and the light works but is not being lit due to a code AND the problem has persisted for enough drive cylcles (5 at the most) then a lot of items can be eliminated.
Unfortunately I cannot think of much that could cause your problem without setting a code. A fuel or ignition problem should cause a misfire before dying..... Air/fuel mixture should also set a code.
Can you think of anything else that may help? Even insignificant items might trigger something.
Old 09-27-2005, 09:41 AM
Re: help
we think we have found the problem it is possible that the fuel pump is shuting down.
thanks for your help and time. 1985 windstar van
with 3.8 engine and has a obd11 hook up thanks again.
Old 09-28-2005, 01:34 AM
wiswind wiswind is offline
Re: help
The fuel pump can fail....and will not set the CEL.
The relay for the fuel pump is inside the CCRM (Constant Control Relay Module).....at least that is where it is on my '96 3.8L...... Later....they moved it into the relay box in the engine compartment.
Pictures of my CCRM are at http://community.webshots.com/album/201931518cScpNK
