Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-26-2005, 12:38 PM
cvs cvs is offline
Car won't start after it rains. Need Help !!!
We have a 92 grand marquis that won't start after it rains. We've already replaced all spark plugs and wires and this yr model dosen't have a distributor cap? Could it be something with the relay switch?????
I believe we had a short once and it was fixed.
Need advise stat !!!!! Thanks
P.S. after it dries out a couple days, the car starts right up.
Old 09-29-2005, 11:33 AM
reekor reekor is offline
Re: Car won't start after it rains. Need Help !!!
The 92 grand marquis has a spark control module mounted on the drivers side metal fender called edis8, it has a wiring harness with a bunch of wires running to it. Check that for cracks or loose wiring, Some times they crack around the wiring harness connector.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
