Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-26-2005, 10:13 AM
xpress60 xpress60 is offline
01 Dakota 4x4 squeaks in 4wd
Hello all, I hardly ever use the 4wd but Katrina caught me at deer camp and the roads got bad. It is a aqueaky almost metal on metal noise only in 4wd at any speed. Underneath I noticed a rubber boot missing from the driveshaft from transfer case to front differential on the joint nearest the transfer case. All fluid levels check OK. Is this a common problem ? How difficult to repair ? How expensive for this part ? Just the joint or the whole shaft ?
Thanks
Old 12-22-2005, 01:56 PM
bmbihntr bmbihntr is offline
Re: 01 Dakota 4x4 squeaks in 4wd
Thanks
I had a similar problem, then it got progressively worse. the shroud over the front drive shaft was loose, dodge replaced the whole drive shaft.
