Old 09-26-2005, 09:05 AM
jamesmartin jamesmartin is offline
service engine soon
Hello everyone,
I think I found a new problem for the Alero. I have a 2001 Alero, the other day I am driving down the hiway, and my door locks start to click locked, unlocked, and then the service engine soon light comes on. I noticed last night my auto lights on my dash did not come on either. Has anyone had any of these problems?
Old 09-26-2005, 06:13 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: service engine soon
These problems are commonly associated either with battery problems, which can include the main battery cables and terminals. You may want to remove them and clean them to see the issue improves. Also check the grounding point to the block. The other possible issue is the body control module going bad. But I would stick to the battery and the cables. Be careful when you unhook the battery as your theft lock may come on and the radio may not work. Have the unlock code available.
Old 09-26-2005, 07:46 PM
vamc's Avatar
vamc vamc is offline
Thats true, a bad cell in the batt. can make the aultanater go bad as well. im not surprised if more lights on your dash came on.
Old 09-27-2005, 11:14 AM
garage says
Well I took it to my garage and they have said something about the remote starter possibly causing a short. They would have to dig around for 3 -4 hours at 92.00 per. I think I will trade this car in this week.
Thanks for the suggestions.
Old 09-28-2005, 09:34 AM
Re: Re: service engine soon
How do I get the code if this does happen? I bought the car second hand.
Old 09-28-2005, 10:07 AM
nqc2k nqc2k is offline
What if he brings the car to AutoZOne and they tell him why his check engine light is on? I heard they plug a diagnositc thing into it that'll tell codes for the check engine light or something...i've never done it though.
Old 09-28-2005, 01:08 PM
vamc's Avatar
Its called a code scanner, and yes autozone will do that for free. they will tell you whats wrong with it. but also, sometimes there code scanner will not pick up everything. the code scanner that they use is approx 150 bucks, the same one you can buy from there. If it cant find whats wrong with your car, bring it to the dealership, they have machines that are 15 grand, they can find just about everything.
Old 09-28-2005, 05:30 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The Tech 2 (GM scan tool) is 2400 dollars. It is capable of retrieving codes and information in all modules, performing snapshots of data streams, plotting infomation and reprogramming modules..all though it is an impressive tool, it doesn't tell you anything..the technician using it must be able to interpret it infomation that is displayed by the tool.
Most likely even though the SES light came on, there may not be a code stored (there is a reason)
If this was a problem with a bad connection at the battery or elsewhere, what my have happened is the PCM lost power momentarily and this caused the PCM to cycle (and the light came on).
Lack of power (less than 10 volts) will cause the vehicle to do wierd things..first thing I would check is the battery connections.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-07-2005, 08:13 AM
Re: Re: Re: service engine soon
If I do the battery check and the lock code enables, how do I get the unlock code?
Old 10-11-2005, 08:43 AM
Now we know,
Finally this weekend my car wouldn't start twice, after boosting the battery would drain. Took it in today and yep the battery is finished.
So a heads up, if your Service Engine light comes on and stays on it is probably something wrong with your battery.
Old 10-13-2005, 04:55 PM
vamc's Avatar
A code scanner caust 150 bucks from autozone. not 2 grand.
Old 10-13-2005, 06:17 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Andrew my friend, GMMerlin was refering to a Tech II scanner that the dealers have. It's much better than any code reader/scanner that you could get from Autozone. And it costs that much or more. He knows what he's talking about and is very sharp on GM cars.
If I had over 2 grand to throw away I'd get one.
Timeslip 08/12/06
AF Community Guidelines
Old 10-13-2005, 10:05 PM
vamc's Avatar
ooooopppps. Im sorry. I know there much better. sorry about that.
