Old 09-26-2005, 09:23 AM
glockman glockman is offline
Is this an even deal? What would you do?
Hi guys, I'm new around here and am looking for some advice. I have the oppritunity to trade my 1998 chevy Tahoe with 101k miles on it for a 1995 eclipse gs-t with 94,000 miles on it. I test drove the GS-T and man is it fast. I do like it, but would it be wise for me to trade it even Trade for my Tahoe? I just put about 1k into repair work into my truck so I know it's going to last me for a while. How well do eclipses hold up? What are the trouble spots? How are the turbos in them? My buddy says that the eclipse has a problem with thier engines on the turbo models. I checked J.D power and associattes and saw that it's marks weren't the best, but I compared it with my Tahoe and they were even as far as mechanical reliability goes and about even all around. I don't want to get a problematic car. I am going to have him put a 2 year dealer warranty on it that covers engine and transmission, is there anything else that usually goes wrong with these things? Is this enough of a warranty? Anything I should know in general? The dealer has the list price of that car at almost 7K$, and on autotrader I see a lot of Tahoes going for about 8K$ with the same year and miles, so I know I could sell it for more, but I kind of want it now. Should I just hold up and sell it and buy a newer one, different car, or will this one be ok?
Old 09-26-2005, 09:39 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Is this an even deal? What would you do?
It's really determined by what you want. If the car was beat on constantly by some 16yr old kid, than you will run into more problems than someone who takes care of their car.
I bought mine from Miss Pennsylvania 1999 four years ago. I have had no mechanical issues to date, other than routine maintenance. She had all the service records and really took care of the car.
Check the records if they are available and see if you can find out when the timing belt was replaced.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-26-2005, 09:55 AM
Is the timing belt expensive to replace? I think that was one of the problems my buddy told me about, that and a little pulley or something that is easy to break. The cars inside and out looks pretty decent, normal anyway, no worse than mine really. The black trim on the outside of the door has started turning white, but I think that is normal with these kinds of cars. I looked at a Talon once that had the same thing going on. Is there some kind of paint you can use to make it look better without having to be a pro?
Old 09-26-2005, 09:59 AM
Also, are these things generally problematic?
Old 09-26-2005, 11:54 AM
Re: Re: Is this an even deal? What would you do?
Once again, it depends on the car and the way it was cared for. Leaving the car stock I have heard nothing but good things about them. Now if you go slapping an FP Green on there with all the supporting mods and running 30psi you should expect problems.
If you pay to have the timing belt done, along with the balancer belt, tensioner, water pump, etc....you are looking around $800, if I remember correctly. You will want to have this done if it is close to needing it. The timing belt is not something to screw around with on these cars, if it breaks you are screwed.
1997 Spyder GS-T
5-Speed
Old 09-26-2005, 12:17 PM
SLoe's Avatar
SLoe SLoe is offline
You know Ms. Pennsylvania? Is she hot?
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 09-26-2005, 12:21 PM
If I do decide to get this car, I'm going to have a dealer warranty. The dealer said the warranty would cover engine and Tranny, would the timing belt be covered by the warranty. Forgive my ignorance.
Old 09-26-2005, 12:55 PM
soapsuds22's Avatar
soapsuds22 soapsuds22 is offline
Make sure to go over the dealer warranty carefully also. They can be very sketchy.(I know firsthand I own a dealership)
Old 09-26-2005, 01:02 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
They will not perform the scheduled maintenace, and if you neglect it and something breaks because you didn't do the maintenace when you were supposed to, the chances of them paying to fix it will be minimal.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-26-2005, 01:07 PM
What should I be looking out for when going over the Warranty? I'm only 21 and haven't really done this before. I don't wanna get burned. I have a good truck, it just eats a lot of gas that I can't afford. I need something that I'm not going to have to put a lot of money into. Would the GS model be better than the GST?
Re: Re: Re: Is this an even deal? What would you do?
I lied, it was 1994......
Anyway to answer your question, no she wasn't. But man, did she ever have a set of legs.
http://misspa.org/past1990.htm
1997 Spyder GS-T
5-Speed
Old 09-26-2005, 01:10 PM
If you are looking for reliability only, I would suggest you go get a Honduh.
As far as the warranty goes, normally they are pretty standard. Powertrain only, and don't cover wear items like clutch, flywheel, etc.
You could always scan it and post up a picture.
1997 Spyder GS-T
5-Speed
Old 09-26-2005, 01:55 PM
I can't find a place to upload pics on this website. I have pics on my computer, I just don't know how to put them up here without uploading them first.
Old 09-26-2005, 01:58 PM
SLoe's Avatar
Re: Re: Re: Re: Is this an even deal? What would you do?
Agreed.
If the salesmen are satan, what does that make the owner?
Old 09-26-2005, 02:01 PM
SLoe's Avatar
Go to the gallery, upload your pics then paste them in your sig.(I think thats how I did it)
