Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-26-2005, 04:35 AM
tractorboy's Avatar
tractorboy tractorboy is offline
Low Oil Pressure 2003 Impala
I HAVE A 2003 IMPALA 3.4L. The manual says that the oil pressure should be 60 psi at 1800 rpm. I removed the oil pressure switch and screwed in the hose for the guage. Is this the right place to check the oil pressure. The dealer has a device that the oil filter is removed and a device is fitted in place to measure the oil pressure. Anyway I measured 40 psi at idle going to 48 at aprox 1800, cold and 38 psi warmed up going to aprox the same as cold. what do you think ?
so how low is low oil pressure ? how low before engine damage ?
Old 09-27-2005, 08:23 PM
phewop118 phewop118 is offline
In most GM's, the standard oil pressure is around 40 psi. I'm not quite sure of your impala, but in trailblazers, intrigues, and impala's with the 3.8, the needle starts a little below 40 psi when warm, and then when revved, can go up, sometimes as little as 0 or as much as 10-15 psi.
