Old 09-26-2005, 04:03 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Lil help - starting issue
Hey guys! My kids 2000 GA SE is having problems starting. It seems that it'll crank but not catch - then he'll give it a second try and it'll catch after a couple of cranks. I'm stopping over tonight on the way home from work to look at it and was hoping for some direction. I'll start with spark but I have a funny feeling it my be fuel. How do I test the fuel system in these? The check engine light isn't on but he's going to have AutoZone run a scan and check the charging system anyway. Thanks!
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 09-26-2005, 05:33 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Lil help - starting issue
I would agree that this is a fuel issue. Check the fuel pressure at the shrawder valve on the fuel rail. You will need a fuel pressure guage. You should see the pressure increase when the pump kicks on, if there is no change then you may have to replace the fuel pressure regulator. The other possible issue is a bad ignition switch. It may not be contacting properly and not allowing the ignition to work the on the first try.
Old 09-26-2005, 01:34 PM
Now my kid tells me a few days ago that his gas cap wasn't on correctly and got the SES light. He had the code checked and it cleared in a day or two. Then he started having problems. Hmmmm......
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 09-27-2005, 10:30 AM
Ok, more symptoms... ...today he got in and the problem was worse. It took longer to start and the clock/ radio was reset. I'm thinking battery or maybe alt now. Anyone else have any thoughts?
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 10-01-2005, 08:03 AM
Well I finally got to look at it the other day and on visual inspection I noticed that his alum intake mount snaped and the tube was banging into the + post on the battery. Auto Bone tested the battery and said it was bad. This was last night. 2 days ago while it was in my driveway I checked the brakes cause they were creaking loudly. I changed out the brakes cause one the pads was shreded and the rest could use it too. I drove the car for a couple of days and everything was great until I changed the battery. My kid picked up the car and drove home but on the way his Trac light came on and the car started shiffting hard. How can changing the battery cause that?
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 10-01-2005, 10:56 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Lil help - starting issue
Did you leave the IAT sensor disconnected?
If so, it will set a code and cause the Trans PCS to go to full pressure and disable Trac.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-01-2005, 04:41 PM
Interestig thought. We reconnected the IAT. He previously was using some sort of bypass he bought off Ebay.
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
