Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 09-26-2005, 03:34 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
OEM SPL / Ring Gears
I decided to make a list of of OEM Replacement Parts or HomeDepot SPL mods that will fit on a 240SX and do something to improve preformance.
Engine
RNN14 Main Caps - Best OEM SR20 Maincaps (ARPs are too longon RWD SRs)
300ZX Filter - Larger, a must for Turbos, Supposed gains for N/As
300ZX / Skyline Fuel Pump - High Flow (190LPH I Think) Must for Turbo
300ZX/Q45 MAF - Flows way more than OE, Cobra MAFs
S15 SR Injectors - 480CC No Modifacation
STi Injectors - 500ish CC. Needs new plug / pig tails but will fit.
Q45 Ignitor Chip - USDM SR Replacement
Skyline Torque Mounts - Stiffer than OEM (What URAS sells for SR)
Poly Filled Motor Mounts - Fill OEM Mounts with Poly Urethane (stronger than Nismo)
Driveline
Z32/RB25 Transmission - Fits SR/KA with adapter plate holds 800whp
Maxima Clutch - Fits on SR as is.
S15 Differential - Helictical / Comes with 4.636 Ring Gear.
Suspension
S14/R33 FLCA - 10mm Longer than S13/Z23/R32 (Ball Joint different)
S13 HICAS Rack - 13:1 Tighter Ratio / More Steering Angle
S13 Tension Rods - When used on S14 will allow for More Caster
300ZX Inner Tie Rods Much Stronger... Require Outer Tie Rods
S15 Rear Sumbrame - Wider / Stronger than S13. can be wedged on with rubber bushings, Solid bushings must be eccentric.
300ZX Brakes - Front Bolton / Rear Extensive modifacation
300ZX Rear Al Uprights - 8lbs lighter Requires 300ZX Rear Shock
Q45 Brakes - Upgrade - good for Wheels with Big Dish.
180SX Brakes - Front is same as 240SX Rear has Bigger Piston
R200 Ring Gears
3.6-- - OEM S15
3.917 - OEM J30
4.083 - OEM S13 SR Powered Vehicles
help from NissanEleitist.
4.364 - OEM Early Model N/A CA
Old 10-03-2005, 02:00 PM
R.W.240's Avatar
Banned
Re: OEM SPL / Ring Gears
Most People that actually make power say the Z32/RB25 Transmissions will hold 600+ Daily and up to 800whp.
Old 10-03-2005, 05:57 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Dammit R.W., you had me all exited thinking that SPL was making aftermarket ring&pinion sets for R200.LoL
-Added to Tech sticky
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 10-03-2005, 07:59 PM
R.W.240's Avatar
Banned
Re: Re: OEM SPL / Ring Gears
Uhhh... who needs SPL... Courtesyparts.com sells all those gear sets for 400 something $$
Old 10-03-2005, 08:30 PM
240SX Guy
Too bad they don't still sell the 3.7 set...
-Cory
12.6@122mph
