Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 09-25-2005, 09:58 PM
GudeCiv's Avatar
GudeCiv GudeCiv is offline
Send a message via AIM to GudeCiv
Super'd Built B18 Questions
I have done about as much research as I can about this combo and I am only hoping to get a few comments from those who have had some experience with a combination as this.
WHAT I AM WORKING WITH....
B18C1:
ITR crank
ITR rods
11.2:1 pistons
ITR oil Pump
ITR spec flowed head
ITR full valvetrain
ITR cams
High Power Cam belt
Adj cam gears
Stock GSR Fuel System (rail, injectors, etc.)
Y1 Transmission:
4.4 Final Drive
LSD
PLEASE COMMENT ON THE FOLLOWING:
ROOTS TYPE SUPERCHARGER AT SIX LBS BOOST
- HONDA THE POWER OF DREAMS -
MY RETIRED MOTOR WILL ALWAYS BE REMEMBERED
SOHC non-Vtec 1.6L 170hp (flywheel)
redline: 8,100rpm ---->
-Gude Race D16Y7 Head
-JDM ZC Block
-Individual Throttle Bodies
Old 09-25-2005, 10:14 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Super'd Built B18 Questions
what are you doing for fuel?
2002 Acura TL Type S
1991 Honda Crx Si
Old 09-25-2005, 10:20 PM
GudeCiv's Avatar
Re: Re: Super'd Built B18 Questions
Walbro 255 in pump
310cc RC's
B&M fuel Pressure Riser
I do not have these on this setup yet although I have used these components on other set-ups and they prove to be the adequete pieces to the puzzle. Obviously I haven't gone much into detail because this is my first B-series experience. If you have other info from experience on any parts of this combo then feel free to inform me. Thank you for your time man.
-JDM ZC Block
Old 09-26-2005, 01:15 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
11.2:1 boosted is fine with some fine tuning, but, for me personally, a no go.
building a high compression block, then boosting it is just too much trouble for me.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-26-2005, 01:38 PM
97integrals's Avatar
97integrals 97integrals is offline
I agree you better have a good standalone and a good tuner. Also I don't see a point to swaping the gsr crank and rods out for the type r components, a waste of money in my opinion.
Old 09-26-2005, 04:07 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
well rumor has it that a type r crank is stronger and more balanced, *shrugs*
Team Lonely Drivers
Old 09-26-2005, 06:36 PM
Yeah I heard that, but the ls and gsr cranks have gone passed 900whp. So I don't see a point in spending more money. But if he wants to spend unnecessary money that’s his choice.
Old 09-26-2005, 09:13 PM
95whitehb 95whitehb is offline
Send a message via AIM to 95whitehb
Re: Re: Re: Super'd Built B18 Questions
I would not wish to spend extra money either. That would be a waste. Yet, the motor is built with it. Is it so important that I swap it out for a gsr crank, no that would be dumb, so I will leave it ITR and let you know I am not spending anymore money for the option. Its a package deal.
Thanx
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap.
'95 CX hatch:
-JDM ITR swap ('98 spec.)
-ITB's
Old 09-26-2005, 09:17 PM
Re: Re: Re: Re: Super'd Built B18 Questions
Thanx
The shop owner who built this motor just used the B18C1 shortblock he had laying around. This is why its all ITR internals. ITR vs. GSR crank? idk But I'm sure I won't be experiencing the differences in my application anyways.
'95 CX hatch:
-ITB's
Old 09-26-2005, 09:19 PM
GudeCiv's Avatar
Re: Re: Re: Re: Re: Super'd Built B18 Questions
UGH and the last two replies were from me and I accidentally was logged in as my girlfriends profile. Apologies.
-JDM ZC Block
Old 09-26-2005, 10:21 PM
Thanx
That was never stated in original post. It makes since then if you got the engine with it in there to leave the itr crank and rods. I didn't mean my last post as a bash on you, I was simply trying to help you not buy unnecessary parts. I was not aware you already have these parts.
Old 09-26-2005, 10:48 PM
AF - Advisor
if you boost, just keep the high compression in mind.
Old 09-27-2005, 04:16 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
that could cause some headaches!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 09-27-2005, 08:25 PM
GudeCiv's Avatar
It will be tuned with Hondata s300.
Is 11.2 too high for 6psi and 93 Octane with a correct tune?
I'm debating what genre I would like to be in then if it requires change of pistons to correct compression to get any practical power from it.
I know enough about All Motor to have some fun.
Still learning about boost tolerances and its other charactaristics though.
About the reply on the ITR crank. Thanx for letting me know. Although the reason I got a little defensive because I thought I typed in the begining what I have to work with and what I am thinking about getting (the charger) Should have reworded. I'd like to keep a good name on this forum since there are some good guys out there that know what they are talkin about. Thanx to anyone helping me out here.
Anyone have experience with Jun Stage 3's and the corresponding valve spring kit? I'd like to get a few personal reviews(power band change, rev tolerances, etc.) other than Dyno sheets and theories on paper. Thanx
-JDM ZC Block
Old 09-27-2005, 09:44 PM
AF - Advisor
if your serious about running the jrsc and plan on swapping out the rods and pistons, throw back in the old gsrs.
if your serious about upgrading the internals other than oem for boost, dont look at the jrsc.
good cams to boost are some $50 gsrs.
