Old 09-25-2005, 07:04 PM
ssatch ssatch is offline
Send a message via ICQ to ssatch
Back Up Lamp Switch
wondering where the switch is located...'98 GMC Z71
neither lamp works and the other stuff on the fuse works so i guess i have a bad switch or a cut wire or an unpluged connector...
Old 09-25-2005, 08:10 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Back Up Lamp Switch
under the dash, above the brake pedal.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-25-2005, 08:24 PM
back up lamp switch
are you sure?..on another forum someone said it was on the transmission...i can check both places in the morning but i need all the help i can get....lol ...thanks again
Old 09-30-2005, 06:16 AM
Bullet[BS] Bullet[BS] is offline
Re: back up lamp switch
It is on the transmission! The earlier style Chevrolets & GMC trucks it is on the steering column by the firewall inside the cab. First take a test light and see if your getting power to the circuit board for the tail lights. If not then check closer to the transmission. DO NOT JUST PULL ON THE PLUGS FOR THE RANGE SENSOR ON YOUR TRANSMISSION!!!!! It is glued in place you need to apply heat to soften the glue to pull the plugs out of it. A hair dryer or heat gun will do the job just fine. Trouble shooting 101 Start at the output if it is bad then move half way back to the transmission if you don't get the proper output then move further back from there. If you get good output then move halfway towards the lights. Best of luck let me know if this helps.
Old 09-30-2005, 10:09 AM
ok, will do !...thanks for the help, i haven't had time to get to it yet but i'll check at the lamps first...i thought it might be a quick way to check at the switch and not pull the lamps ass'y out but that's easy so i'll start there...
