Old 09-25-2005, 06:57 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Fuel Pressure Regulator for Tuning
Question;
When I get the SAFC2 controller, and get my bad-girl tuned, would a fuel pressure regulator help get some more power? Something like this:
http://cgi.ebay.com/ebaymotors/FUEL-...02519406QQrdZ1
Just asking because Ill be tuning hopefully mid-late october. Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-26-2005, 08:07 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Fuel Pressure Regulator for Tuning
Fuel pressure is not something that should be used for tuning. It can bandaid various other shortcomings, but not without bollixing other things. For example,
higher fuel pressure makes the injectors bigger, but make the pump smaller.
Lower fuel pressure makes the pump bigger, but the injectors smaller.
Chaning fuel pressure at all from what the ECU expects will throw off everything it is trying to do (38 psi 1g, 43 psi 2g).
I would not recomend tuning with fuel pressure for these reasons.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-26-2005, 08:09 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Tuning fuel pressure is reserved for the domestic guys, and they rarely do it themselves. And once you start messing with it it's hard to get it set back to where you wanted it.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 09-26-2005, 08:41 PM
david-b's Avatar
Dave is THAT guy
Cool. So is there anything else I should consider getting when I get my SAFC2 controller and before I get it tuned? Thanks
75 Monte Carlo
Old 09-27-2005, 03:56 AM
AF - Advisor
Just a logger of some sort if you didn't mention that already. Many poeple will also do an eprom ecu and a chip of some sort, but at that point you might as well go DSMlink.
Kevin Jewer
Old 09-27-2005, 05:55 PM
david-b's Avatar
Dave is THAT guy
DO I need a logger? A shop is going to do the tuning for me. I dont plan on playing with it once they're done. They got alot of equipment. Should I get bigger injectors and fuel rail? These are newbie questions but I want to get his part right for sure!
75 Monte Carlo
Old 09-28-2005, 07:11 AM
AF - Advisor
That's up to you. I personally don't trust any shops to tune my car, and I would not be able to sleep at night if I didn't have control over the tuning after they were done. Shit, if so I could have gone with a reflash in the EVO like everyone else instead of DSMlink You're call though, do whatever makes the most sense to you in your case.
Kevin Jewer
