Old 09-25-2005, 06:21 PM
doug1946 doug1946 is offline
Dtc P0403
My service engine soon light comes on shortly after engine begins to warm up. The DTC code is P0403 EGR Flow circuit malfunction. I can't detect any problems with the performance of the engine. I just don't like to the the ses light come on. Any suggestions on what is causing the problem? 99 Caravan ES 3.8.ltr V-6. Thanks.
Old 09-25-2005, 09:38 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: Dtc P0403
could be a bad EGR solenoid
it won't effect the prefoemance of you engine. just make sure you get it fixed before your next emisions inspection
Old 09-26-2005, 04:22 PM
Re: Re: Dtc P0403
Thanks for the reply. I will get it fixed soon..... as I have my emisions inspection next month. Is there a way to test the EGR solenoid to see if it is the problem?
Old 09-27-2005, 08:43 PM
Re: Dtc P0403
you would need a scan tool to test it
Old 09-28-2005, 04:17 PM
Re: Re: Dtc P0403
Thanks, I'll have it checked.
Old 10-01-2005, 09:53 AM
SlimJimRD SlimJimRD is offline
Re: Dtc P0403
you can look at the egr valve with flashlight and warm engine in neutral. rev the engine to 2000 and not over 3000 the valve inside will move if okay. This shoes the control system is working otherwise i just replaced the valve
Old 10-01-2005, 05:59 PM
Re: Re: Dtc P0403
Thanks, I'll try that first.
