Go Back   Automotive Forums Car Chat > Land Rover > Range Rover | Range Rover Sport | Evoque
Old 09-25-2005, 06:14 PM
Flimps Flimps is offline
Unhappy Flat Battery
My batery gets flats every 3 days. Battery charges correctly.
Porblem only with the Range Rover. Freelander works fine. Any suggestions?
Old 10-08-2005, 09:25 AM
AndrewP38 AndrewP38 is offline
Re: Flat Battery
Hi,
I have the same problem. This is probably due to electrical interference triggering / waking up the BeCM. Land Rover have a possible fix part ref. ASR 1953 @ approx £110 GB. It is a modification to the aerial amplifier. I suggest that you take a look at andy cunningham's uk web site. The problem is easily checked with a digital multimeter. If the BeCM may also be woken by faulty relays and locks. I have just purchased the part noted above and am due to fit it later today. I have a 1995 4.6 HSE.
Andrew
Old 10-21-2005, 12:51 PM
Two Rangies Two Rangies is offline
Hello,
look at http://www.rangerovers.net/newrremedies.htm
Two Rangies.
Old 10-21-2005, 05:35 PM
Re: Re: Flat Battery
Many Thanks
