Old 09-25-2005, 03:56 PM
Movieguymookum Movieguymookum is offline
Send a message via Yahoo to Movieguymookum
Under Dash? ticking.....
Got a 97 Silverado Z71, 5.7L. Bought this second hand and have had an annoying problem since the get go. The is a tick under that dash on the drivers side while driving. Under load, i.e. up a hill or passing, the tick gets more profound and if the engine loads up it gets heavier sounding and seems to be tied to the RPM of the engine. If you let out of the gas and coast it become barely noticable. You cannot hear it in the engine compartment or when the truck is sitting idling. It sounds electrical much akin to what you would hear when you lay a spark plug on the block to check for spark. It don't sound mechanical, but I can't rule that out cuz I just can't locate it.
Any ideas/thoughts or is this normal for this truck?
Old 09-26-2005, 07:12 AM
67malibu 67malibu is offline
Re: Under Dash? ticking.....
It sounds alot like the head pipe on the driver's side leaking. They will sound like a ticking sound that changes with the rpm and load on the engine but may not be audible at idle. Also, if the truck has headers, the rear area on the driver's side can partially blow out because it is usually a little harder to tighten.
Old 09-26-2005, 08:46 AM
42adult 42adult is offline
Banned
I agree - you have a small leak. I replaced my muffler/converter and that solved about the same issue
Old 09-26-2005, 06:10 PM
Thanks guys. Was looking at a new exhaust system in a few weeks so guess I will go ahead and get the set of headers I was looking at to boot.
