Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 09-25-2005, 03:41 PM
kcia kcia is offline
Which Transmission??
Can anyone tell me from what other years I can replace a 95 Wrangler transmission. Mine went out and can't find a used one of that year.
Old 09-25-2005, 10:02 PM
addihs214 addihs214 is offline
Send a message via AIM to addihs214
Check out www.car-parts.com. They should post the interchange list and tell you whats available in your area. But you probably have either the AX-5 or AX-15. I believe anything 94 or newer will fit. You can get the older models but you would have to change the bellhousing because the earlier models used an internal slave cylinder. Hope this helps.
Old 09-26-2005, 03:27 AM
CanaMark CanaMark is offline
Re: Which Transmission??
They sell adapter plates as well, I forget the company name off hand
Old 09-26-2005, 01:58 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
in 1995 the 4.0l six cly had the ax-15 transmission. the 2.5l four cyl had the ax-5 transmission. The ax-15 and ax-5 are not interchangable. The t-case will not bolt up.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
