Old 09-25-2005, 03:00 PM
garednck garednck is offline
1996 S-10 Charging/Cranking Problem
I have a 1996 S-10 with a 4.3. Recently I had my truck just cut off while driving. Found the battery dead and the Alternator not charging. Changed the battery and corrected the Atlernator, but now at times when I go to start the truck it cranks over but won't start until i hit the gas. The battery gauges shows a discharge and the engine stalls out. I can wait a couple of minutes and then restart it with no problems?
Old 09-25-2005, 03:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1996 S-10 Charging/Cranking Problem
Ever changed the fuel filter?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-25-2005, 03:14 PM
Yes the fuel filter has been changed on a regular basis.
Old 09-25-2005, 03:29 PM
BlazerLT's Avatar
AF -Advisor
check the battery voltage when not running and when it is running.
Report back with your findings here.
Old 09-25-2005, 03:32 PM
Voltage is 11.8 engine off and 13.8 engine running. I can start 3 or 4 times in a row before it starts acting up.
Old 09-25-2005, 03:34 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 1996 S-10 Charging/Cranking Problem
Your battery voltage is low when the engine is turned off.
It should be between 12.6-13.4 volts.
Remove the battery from the vehicle and charge it with an automotic battery charger and charge it completely.
Old 09-25-2005, 03:35 PM
Ok I will try this again, Thanks
Old 09-25-2005, 06:42 PM
I went and recharged the battery like recommended. Voltage at the battery engine off was 12.2 and with engine running 14.3. However when I go to start the vehicle it turns slow or strained as if it has a large load or it's cold outside. After several more attempts it will just spin over until the gas pedal is pressed, but once you let off it is stalls out, if you feather it until the battery gauge starts to show a positive charge then it will stay running. Any other ideas?
Old 09-25-2005, 07:09 PM
BlazerLT's Avatar
AF -Advisor
How did you charge it?
Old 09-25-2005, 07:13 PM
12v charger at 2amp for a little over 3hrs
Old 09-25-2005, 07:14 PM
it was out of the vehicle and i installed battery studs in the side post.
Old 09-25-2005, 07:16 PM
BlazerLT's Avatar
AF -Advisor
Was it an automatic charger?
Old 09-25-2005, 07:38 PM
Yes it was. It has an LED that said the battery was completely charged
Old 09-25-2005, 08:11 PM
BlazerLT's Avatar
AF -Advisor
Almost sound like you have a dead short somewhere.
How did you fix the alternator, did you replace it?
Old 09-25-2005, 08:19 PM
Yes I did replace the alternator and the battery was replaced 5 months ago.
