Old 09-25-2005, 12:59 PM
dss56 dss56 is offline
1997 blazer rear speaker replacement
Bought a 1997 chevy blazer for my daughter and the rear speakers do not work i checked them and they are blown. What is the size of the speakers and what is a good replacement. Or what other gm car can i get a pair out of from a salvage yard in my area.
thanks
Old 09-25-2005, 01:16 PM
Cailen Cailen is offline
Re: 1997 blazer rear speaker replacement
Those rears are 5.25". I wouldn't go to a salvage to pick any up personally as you can get a pair fairly inexpensively, and your daughter would likely be much happier with the sound produced by a $40-$50 set.
Old 09-25-2005, 01:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
thanks
Do you have a 4 door or a 2 door?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-25-2005, 03:30 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: 1997 blazer rear speaker replacement
I don't agree. I have a '97 (2 door). The stock speakers are 6x9 in the rear. The size you're talking about are the door speakers.
Either way (2 or 4 door), take a look at www.crutchfield.com. They'll tell you what fits after you enter your info. Buy at/where your consience tells you.
Old 09-25-2005, 05:19 PM
speaker size for 1997 blazer
The blazer is a 4 door took one out and dont know just how to measure meaning do i measure from the plastic side to side or from the speaker inside side to side. and what might be a good replacement?
thanks for the replys
Old 09-25-2005, 05:41 PM
00BLZRMyWay 00BLZRMyWay is offline
In my year's rear door's, they are 6 1/2." I guess they changed in '98. But to answer your other question, I wouldn't go with some salvaged speakers. I payed $60 for a brand new pair of Pioneers, two years ago. They still sound awesome. These are also being pushed by an amp as well. (not required) Just to put in perspective how long and hard they've worked for me. Never blown a pair. I had some MB Quart speakers go out after 4 months and I payed $300 for them.
K&N won't honor my warranty because I have 1,000,007 miles on my Blazer
Old 09-25-2005, 06:28 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I also have 6.5's. Polk audio all around that sound wicked pissa! I highly recomend polk audio especially when circuit ciy and best buy sell them buy one get one half off. Good luck
ps I went to www.crutchfield.com and it says 6.5's fit your vehicle. Let us know!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-25-2005, 06:52 PM
BlazerLT's Avatar
AF -Advisor
It is a 6.5".
You cannot install aftermarket speaker in the place of factory and still use the factory deck.
The lower resistance aftermarket will eventually ruin the deck.
Old 09-25-2005, 06:55 PM
Originally Posted by BlazerLT
It is a 6.5".
I agree. 8ohm Factory right?
K&N Air Filter
Old 09-25-2005, 07:13 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: 1997 blazer rear speaker replacement
I have seen 5ohm- 8 ohm depending on the year.
Aftermarket is 4 ohm and running a 4 ohm load on a circuit needing 8 ohm will burn the deck out quick and overload it.
Old 09-25-2005, 07:19 PM
Re: Re: Re: Re: 1997 blazer rear speaker replacement
Yes it will. Any vehicle I have owned I always tweaked the stereo. I love my music
K&N Air Filter
Old 09-25-2005, 07:47 PM
speakers
the one i took out says 9.5 ohms and the speaker # is 16158525. Can someone tell me what might be the price for the factory replacemet rear speakers from Chevy.
thanks
Old 09-25-2005, 07:52 PM
Re: speakers
thanks
Some of the factory stuff might be more expensive then buying some cheap after market ones. You can pick up jensen speakers for like $25 a pair when ac delco will probably charge you $50 or $60. But do what you feel is right. I am sure someone on here, most likely BlazerLT will be able to tell you the price for the exact replacement the quickest.
K&N Air Filter
Old 09-25-2005, 08:11 PM
TRACYCULBERSON's Avatar
TRACYCULBERSON TRACYCULBERSON is offline
Yes i also have a 2000 blazer with 6x9 in the rear but not for sure about the 4 door. Dude you can buy a very good set of sony 170 watts
6x9 for under 70 bucks and they rock
FAST
Old 09-25-2005, 08:13 PM
BlazerLT's Avatar
AF -Advisor
Re: speakers
thanks
I would just contact you dealer or hit up a local junkyard for a couple.
Save big money.
