Old 09-25-2005, 01:57 PM
Link85x Link85x is offline
LT4 Hot Cam Kit w/L98
Could the kit be used with an L98? Everything, the rockers, springs, retainers, etc., everything thats comes with the kit.
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 09-25-2005, 03:44 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
it would fit yes... but i've heard that the tpi intake manifold doesn't support the airflow needed for that cam... like the name implies its a hot cam, and you need an intake manifold that can supply the cylinders with the air that that cam wants...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 09-25-2005, 05:04 PM
Re: LT4 Hot Cam Kit w/L98
Vortec Holley Stealth Ram... along with some Vortec Heads...
Old 09-25-2005, 09:33 PM
in that case, you should be just fine... may wanna research more but i don't see any problems with it...
Old 09-26-2005, 09:07 AM
What's the actually lift on that cam anyways. it's says .525int. .525exh, but i think formula said it was actuallt .492 or something like that.
Old 09-26-2005, 01:37 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
I said thats the lift if you use 1.5 rockers but the kit comes with the correct 1.6 roller rockers.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 09-26-2005, 01:49 PM
i was thinking that but i wasn't sure so i didn't say anything... the 1.6 rockers will give you the lift that the kits says right? .525 on both intake and exhaust... if you leave the tpi rockers on there, then you will not get the complete lift the kit offers
also the heavy duty timing set is recommended to go with the kit... i'm not sure what the cam gear on the tpi engines is like... but the heavy duty kit uses a solid cam gear which will allow you to turn rpms above 5500... which is a beatiful thing
